Mayhew 5-Piece Punch & Chisel Set Question
Davefr
OR
Mayhew is excellent quality but my hunch is that set is pretty wimpy in size. (More for homeowner, DIY projects then automotive suspension work.)
The punches needed to work on most suspensions are pretty big. That pin punch looks like 1/8".
It looks like HD's description is non existent.
W
winlinmac
USA
Thanks for the responses, what is a good set of punches for suspension work in a similar price range?
Vantastic
Penns Woods
That is a great starter set. Use it till you can figure out what you will actually need to do whatever you are doing.
What suspension work are you talking about. A larger pin punch set and alignment punches are probably all you'll need.
kunkernator
US of A
Do yourself a favor and go check out Mayhew's website. I LOVE Mayhews striking tools. They have two different lines, the "select" and "pro" lines. The pro one is similar to what you will buy off the tool truck, but at a much better price, and has a lifetime warranty. The select line is still US made, but not as good quality, with softer steel, and has a limited warranty.
I own a bunch from both lineups, and the Mayhew pro line is the way to go. Go check out the website, find a set you like, then Google the part number and buy it!
For example, i just received this Mayhew pro alignment punch set from Amazon yesterday. Under $30, compared the the same set Matco sells for over $150.
This would actually be a great set for suspension work, longer sizes then what come in their multi sets.
Tinner
N.E. Wisconsin
Re: Mayhew 5-Piece Punch & Chisel Set Question
Actually there are 3 lines, Select, Pro and 150. The 150 line is listed separately under the Pro line. Those are the ones that are the same as Snap-on. S-2 steel, good stuff. The regular Pro line is still very good, would suit most of the folks here well. The Select line is totally unremarkable, some of the Taiwanese stuff is as good or better.
W
winlinmac
USA
For suspension work, I was thinking of using a punch alignment set particularly for removal of long bolts (stuck) near and around the upper, lower control arms, and separation from ball socket.
W
winlinmac
USA
Thanks, do you have the link for the sub $30 Punch set? Thanks
W
winlinmac
USA
Thanks for the feedback, which one is a great starter set for Punch & Chisel Set? Mayhew or Proto? I'd go with something of a lower count just as you mentioned, so that I can figure out what I actually need for the chisel stuff.
I purchased smaller $10 set from Sears Craftsman Made in USA; that set looks more applicable to working with leather material.
W
winlinmac
USA
Dasco Pro is good for the Chisel Set Option, lots of reports of chipping on the Select line of Mayhew Sets
anndel
Hawaii, USA
I have their Dominator pry bar set and they're awesome. I wouldn't hesitate to buy more of their stuff. Solidly built at 1/3 the cost of Snap On.
