Right, well l figure l'd have to use a different blade.The blades for meat cutting are quite different. However, there are several different wood cutting blades, depending on whether it's resawing, ripping, curves, et al.
jack vines
I don't have the pictured saw, it was just on Craiglist.As has been mentioned, just for CUTTING, first look at blade speed. Meat saws generally run quite a bit slower (fewer blade feet per minute) than what a wood saw blade would want to be run at. There may or may not be pulley adjustments to up the blade speed.
The structure of the saw is generally more light weight. Might not be able to tension a wood blade sufficiently which is most important. Secondarily, the table is generally lightweight stamped metal and there are no provisions for table tilt, a fence, etc.
You might be able to use it for basic wood bandsaw needs. Or the saw may be structurally and mechanically incapable of meeting the needs to properly tension and turn a wood blade. You could still use it, but you might find it might be frustrating. Or semi-dangerous if you run the blades off the wheels trying.
My gut reaction is resawing blanks for bowls will overtax it, but I'm not familiar with your saw.
If it does work for you, congrats!
I am reminded of the saying: "Anything seems possible when you don't know what you're doing."Meat Bandsaw use for woodworking?
Anyone done this?
I can't see why not?
Oh, Ok, sot so good for resawing.Try looking up the specs on a meat saw & see how they compare, probably doesn't have the power or accuracy as one made for resawing, I do like the large table. Here's one I saw at grizzly, probably better off with one meant for wood.
Grizzly T32304 - 10" 3/4 HP Meat-Cutting Bandsaw - Grizzly Industrial, Inc.
<h1>T32304 10" 3/4 HP Meat-Cutting Bandsaw</h1> <h2>Ready for the toughest of meat-cutting jobs.</h2> <p>The T32304 10" 3/4 HP Meat-Cutting Bandsaw is designed for cutting frozen or near frozen meat and bones.</p> <p>It has an adjustable fence and meat pusher help you cut everything from steaks...www.grizzly.com
Thank you!Just for reference, I know of several forge shops that use modified meat cutting band saws to saw flash off of larger structural aluminum forgings. They are suspended from a jib crane so that they can be swung around the part's perimeter once it is positioned on a stand. The biggest changes to the saw are adding some handles and an eyelet to the top to hang from the jib crane. Granted, we only use this on aluminum, which is quite soft so the meat cutting bandsaws work OK on it. I have never seen these saws used on metals other than aluminum at the plants I have seen them.
I have seen other wood working tools used on aluminum so there is some anecdotal link between meat, metal, and wood.
Here's a picture grabbed from the internet with a blue one in the background.
I think going back to your original question, you need to work backwards from what you want to cut, then select a blade, then see if the bandsaw you are looking at can support the correct speeds. Not saying it can be done, but it is within the realm of possibilities. Just because it was originally designed to cut meat/bones does not mean it can't be repurposed.
I would think one of the differences in a bandsaw designed to cut wood and one for butchering would be accuracy of the cut and specifically the guides for the band saw. If you are looking for the best results possible in wood, probably limit yourself to tools designed for that. If you just want to make a cut and don't care about blade drifting or perpendicularity, then I would think the meat cutting one would be OK.
Edited: clarified some sentences above the picture and added paragraphs below.
I just missed an older Delta 14" bandsaw in nice shape fore $100.00!This one is a decent machine & can add a riser kit to get 12" of resaw, you definitely need power to resaw & a good blade. I would keep looking for a dedicated wood machine, around me bandsaws pop up a lot.
https://www.grizzly.com/products/grizzly-14-1-hp-deluxe-bandsaw/g0555lx
I'm not trying to dissuade the op but you need a good band saw for resawing, especially if its seasoned hard wood, good roller bearing guides,I don't see the meat ones as really being precision machines.The meat band saw I see in the meat market are really sturdy.. not sure if the same is on the one you are looking at... cuts through hard beef bones like butter. and its stainless too.
Actually, around my part of the world someone having their own butcher shop in the garage or shop isn’t that uncommon. But it’s a state where hunting and agriculture make up a lot of business and hobbies for folks.LOL I have never have a precision cut beef bone to the .001" but they are pretty uniform in cuts. LOL.. I don't have any real experience on that department other than what I see on the meat market, they cut it in front of you... when they cut the bones for me, give me the creeps...
on that side note: OP, man if you are going to check that out, just make sure the owner didn't greet you with a skimask on or something... Not normal for some home owner to own a meat saw for some weird reasons or what not.
I’ve been to a few garage/estate sales that definitely gave me that vibe.lol remind me of this commercial... but yes, Just saying... not sure if ski mask is common though
