bwringer
A light bulb is also great for putting a load on a circuit. This is a good way to track down almost-broken wires, or connections or wires too corroded to pass more than a trickle of current.
Sometimes (too often, really) you find something where the voltage reads just fine, but there's just one strand of wire still connected, or there's hidden corrosion. A meter or small test light will read good, but with a load on the circuit you can reproduce the problem and start finding it.
Whether you're a pro or an amateur, the more you learn about diagnosing and fixing electrical problems, the more you'll rise above the mere parts changers. Far too many mechanics are scared to death of wires.
