Wrench97
A PP doesn't load test the circuit.I don’t think a power probe lets you change resistance, but have you ever used one?
But if the circuit is loaded already it will give you a voltage reading.
Right! You can't do it with the fuse cuz it's constantly blowing it and plus the bulb is taking a lot of the load.Some aspects have already been mentioned
So one of the features is to be able to energize (run current) shorted circuits to make measurements not possible with any kind of fuse.
Some of our newest equipment has 10 CAN lines and 1300 rungs of ladder logic across 14 modules. Split 12/24V system. Labscopes and software like Canalyzer are going to become the norm. The big talk is switching from J1939 to Ethernet due to data rate/speeds necessary to keep everything happy. So it'll be a whole new game all over again.
If it was a Chevette that's probably the first time that poor thing experienced proper torqueRepeating myself here but I got away with it once.
If I recall correctly it was an external coolant leak.
It was a little 4-cylinder Chevy chevette or something like that.
Or maybe a little 4-cylinder Chrysler product.
Part of me wants to go to a dealer or make specific shop, and do nothing but driveability and electrical. I know I'd make less than battling rust, but when one has proper service info and wiring diagrams it's just so satisfying to diagnose things. I'll be 31 this year, I think I'll finish out my career doing mostly ICE. 20 years from now, when the 2022s are shitboxes, IMO it's over and they'll be unfixable and disposable.
Radio controls climate control, and works as the central gateway too. It fails, brings down EVERYTHING, now the car doesn't do anything as the keyless entry module can't talk to the BCM, PCM, etc. Okay, well you need a virgin module, and OEM brand whoever stopped making them 10 years ago, NLA. Vehicle totaled. Or lets say the touch screen dies, still works as a gateway. No heat or AC now, still need a virgin module, needs programming, it goes on. Ethernet...... your cheapo amazon code reader ain't talking to those ECUs either. BTDT, need to buy the adapter for my Autel, Solus has it built into the cable.
Hell people are FINALLY waking up to battery costs. No more $109 batteries installed. It's an AGM the size of a cinder block, you're getting 0.5 and more just to get the thing in and out, relearn the charging system adaptive etc. It's not 1965 anymore kids.
I think you're right kroil is better..........
I still want to try that acetone and ATF mix everybody's talking about, I still got all my stuff in storage I don't even have any acetone or ATF here where I'm at but I got PB blaster this last time on Amazon cuz it was a good price but I don't think I'm that crazy about it to be honest.
My one buddy he's a dynamite wrench he swears by Kerr oil
Uhhhh no, never. Example: Shitbox was properly diagnosed to have a failed alternator. Said shitbox is newer than '99 and has 15 modules that should be relearned before returning to customer that just wants back on the road asap. Power windows, sunroof, SAS, throttle body, whatever... Yeah not a big deal to do with most capable scan tools but takes time. Lets say car has some battery life left and it tests good: Isolate + battery cable to alt and pigtail. R&R alt. Charge battery. DONE No screwing around with customers settings, etc.Yeah right LOL and while you're at it after you replace an alternator just leave it running and pull the battery cable off,
if it keeps running the system's charging........... not![]()
A Load Pro might help with that. I've been interested in getting one to play with but never have.A PP doesn't load test the circuit.
Been to McKees Rocks many times. Brought my Roland piano at Hollywood's in the rocks.When I first got out of the Navy I worked at the Texaco in McKees Rocks. Same guy operated the one when you first crossed the line into Pittsburgh.
Yeah, that's a good idea if you're careful.Uhhhh no, never. Example: Shitbox was properly diagnosed to have a failed alternator. Said shitbox is newer than '99 and has 15 modules that should be relearned before returning to customer that just wants back on the road asap. Power windows, sunroof, SAS, throttle body, whatever... Yeah not a big deal to do with most capable scan tools but takes time. Lets say car has some battery life left and it tests good: Isolate + battery cable to alt and pigtail. R&R alt. Charge battery. DONE No screwing around with customers settings, etc.![]()
I guess I thought I was being funny.
I was trying to be sarcastic and funny about testing the charging system like that
Sorry for the confusion I seem to be good at creating it......
Torches are Awesome.I tried the ATF and acetone mixture wasn’t really impressed you might as well use straight ATF or KROIL itself and skip mixing. Tell you the truth penetrating oil alone doesn’t really do that much to me, add it in combo with heat whether torch or induction heater and that’s the best in my book
Since switching to Jack of all sprays I'm really happy. That stuff frees up virtually everything I spray it on. It's amazing how I expect it to work now and it does.I think you're right kroil is better..........
What's Well-known member "65" 65 years old? (That's what I am, well 66 this month)When I first got out of the Navy I worked at the Texaco in McKees Rocks. Same guy operated the one when you first crossed the line into Pittsburgh.
Use a light bulb same results for a lot less money.A Load Pro might help with that. I've been interested in getting one to play with but never have.
Here's a method that I've used to remove those stuck oil filters, I haven't come across one yet that I haven't been able to remove. 4 holes in the filter cap wrench and 4 3/4 #10 self drilling screws. The screws **** up tight and self seal so the oil doesn't leak out.
Interesting! I'll have to give it a shot.
Dodge LA series engines, 273, 318, 340, 360. Match the bolts length for length. NOT Torque-To-Yield.Yes I have done the bread trick it works on water pipes
Probably just shove the bread in the pilot bearing and put a dowel in there,
And hit it with a hammer like you would with grease to force the pilot bearing out
What is a la head bolt?
I don't mind it's yours to do with as you please lol, make sure you use the zip screws with the point, if you use the tech screws with the drill on the end they'll strip out that metal is awfully thin on those filters.BRILLIANT! I'll steal this, if you don't mind. I mean, I hope I don't have to, but it'll come up sometime I'm sure. That's a simple fast solution when you have access to the end of the filter like that.
I bought one years ago..... would not recommend as their are better options. Although it does what it says it will do, and it worked for me as a testing tool for the basic work I did.
IIRC it's a 600ma load. My issue is the design of the tool itself. Yes, push the button, at 600ma, confirm your results on the meter are still good. Yep, that works. Problem is with the physical design. The tip is a standard meter tip size, so.... it doesn't fit anywhere. I don't remember if it has a little gator clip included, I don't think it does. So now you need jumper wires to actually connect this thing into a circuit. 600ma is a good load for a vent valve. I'm not condemning a block ground or fuel pump with 600ma. It's not a "bad" tool. The older videos I saw were of the designer using it on trailer wiring. Probably works awesome for that. Solid tool in that environment. Issue being I find it difficult at best to insert into a circuit to test it. I would say it would be more valuable with a banana jack at the nose to add a standard leads and probes to.
Turning 30 next year myself... I'm slotting myself into EV's now as my agency is diving headfirst into them. I got away from cars because I thought they were needlessly complex and now look at me, hahaha.Part of me wants to go to a dealer or make specific shop, and do nothing but driveability and electrical. I know I'd make less than battling rust, but when one has proper service info and wiring diagrams it's just so satisfying to diagnose things. I'll be 31 this year, I think I'll finish out my career doing mostly ICE. 20 years from now, when the 2022s are shitboxes, IMO it's over and they'll be unfixable and disposable.
If you're getting it now, we'll see it in 10 years. We still have a handful of equipment on Slick 50, haha.Heavy equipment is in the Ethernet world now. Cat’s next gen excavators implemented an Ethernet backbone. Lots of CAN still in use but more and more Ethernet rolling out. I’m told Leibherr has been in Ethernet for a while. Going to be interesting when the typical wiring damage for normal harnesses hits those tiny tiny wires and connectors.
Hell I'd just swap in the horn relay. If it gets a fuel pump running I can live without a horn on the drive to the parts store. LOLSheesh this got off topic for a while, two pages with lots of anecdotes about Pennsylvania.. Those headlight test bulbs are a clever idea; I may have to steal that.
Something I've recently learned was always carry a spare relay in your old truck. You can feel how cheap they are and they take minutes to replace when it dies alongside the road.
Yeah, I agree.This thread deserves a bump. Some real good advice here.
Yup, that's why a finagled a 3' impact extension out of one of the trucks. One end goes on my 1/2" IR and the other takes my 3/8 impact swivels. Get someone to guide the swivels on and transmissions are out in a matter of minutes.Yeah, I agree.
Here's one I, well, reinforced just yesterday: make sure you have the long stuff.
Whatever tools you use most, put together a supply of the loooooooooooong versions. You can often save an impressive amount of disassembly time and angst if you can snake a foot-long tool into tight spaces instead of taking half the vehicle apart.
Yesterday, my foot-long ball end 4mm hex driver absolutely saved the day when replacing a throttle cable on one of my motorcycles. There was just enough room to reach in there from the left side of the bike. It had to be a ball end because there was no access to the throttle body clamps straight-on, and only a skinny little driver could have worked its way through all the assorted wires and hoses; a socket on an extension wouldn't have made it.
There is at least one guy on every shop who is taking one of those fasteners and hiding it, and then having a great day three weeks later watching you search for it.Work on a clean bench, keep parts organized for ease of assembly and to minimize chance of making an error or forgetting something
fireballtool.com
One more very specific recommendation proven through recent experience: if you work with very many hex socket fasteners (AKA "Allen Head"), the you MUST get yourself some Wera Hex Plus tools.
we used to live there.Sheesh this got off topic for a while, two pages with lots of anecdotes about Pennsylvania.. Those headlight test bulbs are a clever idea; I may have to steal that.
Changed out a 2" fitting in the bottom of a 30 gallon oil reservoir on a ag-sprayer, with the hydraulic tank full. I was at a customer that needed the replacement fitting. I had a tech get a shop vac, vac hose into the vent/filler on top of the tank but not in the oil, taped off to seal it. Made sure there were no other air sources into the tank. Turned on the shop vac, sides of the tank went "doink" when they got pushed in by outside air pressure. Disconnected the main suction hose, of course there was oil from that. Then had the tech remove the 2" fitting, put the new fitting in place. Could see the oil moving in the tank, but do NOT touch/disturb it. New fitting in place, attached the suction hose. Turned off the shop vac and removed the vac hose. Maybe got 1/2 a quart of oil on the shop floor.
I must have one of those guys at my house. Every time I disassemble something, I always find I'm missing one or more fasteners!There is at least one guy on every shop who is taking one of those fasteners and hiding it, and then having a great day three weeks later watching you search for it.
