Media Center Ideas
dirtrunner0519
I have been looking for ideas on a media closet/area under the stairs for my amp, network switch, etc. I need it to be somewhat dust resistant but still be able to breathe.
Any ideas.
jd_1138
NE Ohio
Maybe put a slotted/vented at the bottom of the door that you build. You could attach a fan to the bottom to **** in fresh air. I don't think you'd need to vent the air out to the basement. You could also put some vents in the risers on the stairs to air it out.
3pedal
Brighton, CO
I have been thinking about something similar. I am not putting under stairs, but want to keep the stuff cleaner but still ventilated. I am considering pegboard sides or the top with tight window screen covering the inside of the panels to keep **** and bugs out.
Stuart in MN
Minneapolis
Any ideas.
Where are the stairs? In the garage, the house, somewhere else? What's the environment like?
D
dirtrunner0519
Currently the stairs are in the front of the garage. Garage is completely separated from the house.
PhysicsDude
Dallas, TX
How much heat will you really be generating? I built a mini media center with a router, switch, and media server (rack-mount computer with 8 hard drives), and the closet does get a little warm, maybe 8-10 degrees warmer than ambient, but that's not hot enough to cause me any worries.
I think you'd have to have a lot of stuff running in there to really justify a fancy cooling solution. And something like an exhaust fan into the attic might end up costing you extra if it ***** up all your A/C.
