Thanks ishiboo, I have it all assembled and everything fit as it should and no missing parts. Tomorrow I'll grab a qt of 10w30 and 2 gals of AW46 and fire her up. I see some reviews online of the fittings leaking, so they recommend taking them off and re-teflon taping them, but all but the two un connected fittings did I teflon and tighten. The others look good and tight and have teflon on them so I won't redo those unless I make a mess and have leaks.
The online manual I downloaded said 32 or 46, the one that came with it recommended 32. Just FYI.
I don't recommend teflon tape for hydraulic connections, use a liquid instead.
My skid loader is at my friends business for plowing snow (plus it's near one of my rentals so I use it there), so I unloaded it by hand. The beam with the cylinder is HEAVY. What's cool is you can stand it up and then pin it to the trailer and pivot it down. But if you have 2 people, it'd be very easy to do.
Everything is well-made, protected and packed, and assembly was fast and easy. No way I'd pay to have it done knowing how little there is to do!
Can't wait to split some logs
