JordonMusser
Ive seen a few posts on this including this one:
www.garagejournal.com
But I want to expand on a few elements.
This is for a home shop, so relatively small duty cycle. Right now I simply move my shop vac around and vacuum up messes as I go, sometimes rig something to put the pickup in a way to grab dust as I drill/cut etc.
I of course do drill wood, etc on occasion but I try to do that outside generally (all my wood tools stay folded and away)
Since I am basically happy with the power of a shop vac next to me I first considered just running a pipe system with some drops and valves so I didn't have to keep carrying around the shop vac. The I thought, might as well buy a bigger 600cfm ish ~1hp dust collector setup from Grizzly etc (cheap, etc) and run 6" ducts.
After reading a bit about that, it was clear that it was not recommended due to potent fire (hot metal chips into dust cloud) and it may not be powerful enough for metal.
Yet its probably 5x what my shop vac can do. and I have never had a fire.
So trying to bridge the gap b/w these two things. Note that most of what I would do would be post-work cleanup, not insitu dust collection although I would do that too (chop saw, belt sander).
I would intend to use a cylcone style dust collector into a bucket vs the dust bags a wood unit would use (so not running "through" the motor). Was thinking maybe a little bit of water in the bottom of the bucket as well.
Questions on Garage Dust Collector/Vacuum Setup
I am looking to build a whole shop dust collection and vacuum setup using my Shop Vac 12 gallon vacuum. I believe it is either 4.5 or 5 HP. My question is regarding vertical runs and lengths. I would be storing my shop vac in a corner of the garage with a remote power switch. I would then be...
