Metal ceiling direction
jhelle67rt
Working towards getting the truss and roof installed on my 40x50x16 garage. Question came up about metal ceiling installation. I need some opinions. Building is 40’ wide with double garage doors on the 40’ end.
Is there any logic to which direction we run the metal ceiling? My instinct says run it with the lines running front to back. Contractor thinks side to side but I don’t think he particularly cares. The panel lengths are 3’x10’3”
Thoughts?
BobnCO
Perpendicular to trusses is very traditional and the best option. Parallel is heresy!
Bob in CO
(Claiming "master Builder" title
J
jhelle67rt
It’s a hip roof so the trusses go in both directions depending on where in the building you are. Trusses are 24” on center but he shows plans to run “perlins” front to back. I can upload a truss plan tomorrow if it helps with the visual.
J
jhelle67rt
His plan was install Perlins across the building shown as the blue lines and then install panels shown as red.
kwb
PNW
Length of building, a bit of blocking in the hip ends. This would be lowest cost material wise.
I can't say if the builders approach might be a total lower cost due to labor.
I would also prefer that the lid be attached to the structure(trusses) via screws than to a grid attached with nails to resist gravity.
mitusa
SW Oklahoma
Are you using R-panel for the ceiling???
What are the plans and why the short sheets (10 ft long)?
How far apart are the rafters?
I've used R-panel on rafters 8 feet apart with about 6" of cellulose cover and haven't had any sagging and it's been up there for over 20 years.
J
jhelle67rt
Rafters are 24” apart
Mostly around here we see Ultra rib panels. It is spec’d for 26ga Ultra rib with 12” of cellulose to achieve R30. Sheet length seemed to be what most people go with for ease of handling and installing at 16’ high. This is what the metal supplier suggested as they routinely do this.
J
jhelle67rt
That’s what I’m thinking. Going around and adding all the additional wood across the entire building seems like a waste. I’ll look at the plans more but I feel like the added blocking is easier and more cost effective then run the panels with the length of the building
mitusa
SW Oklahoma
Maybe it's just me.....but I would run the ribs along the long side of the building. Save the extra material and time...
The building I built was 32' long and I ordered the metal that long. It took three of us but we got it put up without any lifts.
J
jhelle67rt
You ordered 3’ wide panels 32’ long?!?!
Bert_
NW Iowa
32' is a long panel to hang on a ceiling. Definitely would need enough help. 20' is extremely common. I would doubt any contractor who wants to hang 10 ft sheets. That's really weird.
Jeff Ivers
Oklahoma
On a friend's smaller shop, the decision was made based on one of the dimensions allowing for metal pieces that went all the way across, avoiding intersections of 4 different pieces of metal. On your shop, I would think the cost of materials would be the same either way - but which way allows for the fewest pieces of metal and 4-way joints to deal with?
NUTTSGT
Northern Central Ohio
That's what I would do, run the length of the building and blocking in the hip section.
Have them put the panels up so the seams/overlaps aren't readily seen from the usual way of entering the garage.
mitusa
SW Oklahoma
yep.....ordered them that way. I did the ceiling first...had a friend on each end and would let them get them where they wanted and then push up on the middle to fill the distance.
Of course, it was only an eight foot ceiling and that made it considerably easier. I did the side walls the same way.
J
jhelle67rt
Wow-that’s a pretty large panel. I’m not sure I would have tried it on an 8’ ceiling and I can promise you I’m not doing it on a 16’ ceiling.🤣
I do think stretching out the panel lengths makes sense as 10’ panels seem short
