got2boostit2
Very nice
Most laser/waterjet/plasma vendors can cut that for you probably for less than $50 around here. A jig saw and some patience will do it too.
Anyone in Boston with an oxy torch he could borrow?
MCOC
Now that you have the rough shape in, I'd suggest using tin snips (if you have some to cut whatever gauge that is) to get closer to the final shape, THEN use your dremel to finish out the desired shape.
Though, depending on gauge, maybe forget that idea.
Stunned. Absolutely excellent craftsmanship of combining two medias... wood and metal.
This table makes everything I've ever made for INSIDE the house, look... inferior. You understand that I will definitely have to steal this idea now, right?
Hey white91! That table is turning out awesome! Not sure if it was mentioned but could you put some kind of hood strut in between the hinges maybe so it will open and close slowly?
This is what im using. Not sure if it's technically scotch brite
