Mexican mini-split?
no704
Buddy of mine claims he can get mini-split systems from Mexico sub $200. Any experience?
chinboys
Is that an ice block with a fan behind it?
Did someone separate the evaporator from the condenser and compressor off a 10K BTU window unit?
Did such "fall" off a truck?
Did it come off someone's house while it was working at someone's house?
If it sounds too good to be true, then I wouldn't fall for it.
pcmeiners
"Is that an ice block with a fan behind it?" :thumbup:
Yes I know a Mexican businessman in the copper recycling business, he also supplies cheap minisplits; place the order before 12 pm and he will have a minisplit for you by 6 am. ;)
nsula_country
Northwestern Louisiana
A friend of mine said he found mini-splits; $500 1 ton and $900 2 ton... Told him I'd commission them, but no warranty.
Edit: Went back and read the texts. He said $500 for 1 ton and $900 for 2 ton were RETAIL! Some guy in Texas bought a container full... So yes, they could be $200 MS units wholesale?
CT
Miss the Pontiacs
Saskatchewan Canada
jshillin
PA
I've never ran into any for $200, but they can be found for under $500.
STx
We use those in our rentals and I have one in my shop office. The one in my office is a Duventas, instructions were all in Spanish. They work fine and in general, I consider mini-splits throw away items anyway, it's almost always cheaper to swap one out than to repair it and it's definitely faster. The only thing that's kind of odd about them is that the power is at the head unit instead of the compressor, not really a big deal. Most of them come with wall plugs on them, we cut that off and splice them in a work box with a blank face plate but, you could just as easily plug one into an outlet and save a little time. I think I've got 6 or 8 of them installed in rental units now and we haven't had any issues with them in 2 years. All of them replaced more expensive units that only lasted 4 years before having some issue with the control boards or some other electronics. When you're only getting 5ish years out of them either way, there's no reason to spend 2-3 times as much for instructions written in English.
