Mid-range torque wrench
allinon72
Indianapolis
One of the few HF tools that I use regularly is their 1/2" torque wrench, which gets great reviews overall. However, I guess it doesn't like operating at its max of 150 ft/lbs because something snapped inside the head. Now, at $10 I'm not upset, but I can't afford to replace it with a truck brand wrench. Are there any decent mid range torque wrenches out there? Craftsman is out of the question as I already turned 2 of those into expensive breaker bars.
kts
MD
I'd take a look at Gearwrench's torque wrenches. I've used their digital ones which are more pricy ($200ish) but are really nice. They have non digital ones which are about half of that and have great reviews.
Hootbro
Delaware
Quite honestly, as much use as I have gotten out of my 1/2" HF torque wrench, I would just buy another one and march on.
Leadberry
Akron, OH
+1 for Precision Instruments. Also 100% American made. They do everything in-house down to the polishing.
celticbhoy
Any torque wrench that's constantly used at it's limit has a greater chance of breaking. I'd buy a 50-250 torque wrench next. I'd buy a CDI one. Great reviews, similar to snap on, third of the price.
A
allinon72
Indianapolis
Alright so I've looked into this more. I had no idea the Gearwrench was USA made, which is awesome, but has mixed reviews. I don't like the 15lb increments and the plastic handle (c'mon, even the HF is all metal). Then I saw a Husky at HD, also mixed reviews. I'm pretty sure it's a rebranded Gearwrench but much less expensive. So for a CDI from Amazon is on my short list. All metal, 10lb increments, USA. It's about $130, which I can swallow.
ex-x-fire
Sheboygan Falls Wi.
Put a proto rebuild kit in it, that's what I did.
619DioFan
San Diego , Ca.
I have the husky brand torgue wrenches in 1/2 and 3/8 drive. they have held up well. think they are a good value for the price.
ex-x-fire
Sheboygan Falls Wi.
What torque wrench did that fit into?
I have a proto ratchet like in the picture, I took the parts out of the head to see if it would fit into the head of my hf torque wrench. It fit perfectly. So I ordered up a rebuild kit, hf must have the right to copy that head design.
NC-Fordguy
Check out the lowes kobalt line if you're wanting the metal handle. They have 1/2 drive that's rated to 250 foot pounds for around $100
Got no complaints with mine
bcradio
New Mexico
Same here... I love my Kobalt torque wrenches. 250 ft lbs would fit nicely for you it sounds like
SMKS
USA, planet Earth
+1
I've used the hell out of mine, too. It's not as nice as my CDI or Armstrong torque wrenches, but it works fine.
But, the next best step up would probably be the Gearwrench torque wrench. It's made in the USA and appears to use the same head as the Armstrong wrenches.
The problem is that unless you have some amazing deal on Proto rebuild kits, a Proto rebuild kit will cost more than an entire new HF torque wrench. That is, unless you scam Proto out of a free rebuild kit under warranty, which I don't condone.
EDIT - I just tried to swap a HF torque wrench kit and a Proto ratchet kit. They're similar, but not identical. The differences are in the pawls. With my ratchet and wrench, you can put a Proto kit in a HF torque wrench, but you can't put a HF kit in a Proto ratchet.
Hootbro
Delaware
Those PROTO pear head shape ratchet patents have long expired. Anybody can copy that and not have to pay PROTO anything.
shampoop
SW Washington
That's awesome.
How was the ratcheting action before/after the swap?
ex-x-fire
Sheboygan Falls Wi.
The original gear started to round on a couple of teeth, so it would slip. Works great now.
Theres another write recently that has some good pictures on the swap.
