Mig pliers
PavelK313
Having difficult time finding quality pliers for MiG welders.
Can anyone suggest USA, German or Japanese made pliers?
Ericmacc
MN
Try welpers. I believe there made in Japan. I use them everyday at work and there great.
bluesboy
new york
The Chinese made Lincoln branded pair sold at Home Depot are pretty good for $12. Channel locks are highly praised, $40 is to much for me. JMHO
deange
360 9" WELDER'S PLIERS
The Channellock pliars are the best ones I've used. They are still made in the USA too.
Jlarson
Channellocks for me, I have several pairs around. Most mig pliers are a little small, the channellocks are more comfortable for me.
bob15
Northeasten, CT
metaleltr
Western Ohio
Channelock, I bought a cheap pair before channelock started making them, not worth it and they never got used much, after I bought the channelock ones they now live on my mig welder.
jumbojak
Surry, VA
I have a pair by Irwin that seem to work well enough. I think they were five bucks at Tractor Supply.
Wamsutta
Amarillo, Texas
Which grips are better?
P
PavelK313
Thank you for replies guys! By any chance does Sanp on or Knipex makes some? I am sure i already know the answer (which is no) but maybe i am missing something .
AngryBeaver
Lake Milton Ohio
Am i the only one that doesn't use them?
A quality pair of dikes will losen the tip and snip the wire..
Got pair "free" with my welder 20 years ago and haven't ever used them. I've got enough pliers
dr_clyde
Holland, MI
I much prefer the Pearson Welper over the channellock. The channellock ones don't snip the wire clean when the wire is all the way into the crotch of the cutter. There is just enough of a gap to not make a clean cut. I gave my CL ones to my dad.
The welper is like, $30 or so. Worth it.
WittHay
Surrey, BC Canada
Old pair of dykes with enough good spot on it to snip welding wire.
Am i the only one that doesn't use them? A quality pair of dikes will loosen the tip and snip the wire..
I have a pair of the blue handled Channellock mig pliers. But most welding guys I know if you hand them a pair of fancy welding pliers, they will look at you funny.
They just use a set of side cutters, easier to use when the wire, bird feeds in the machine itself
RustyJunk
Pasco Fl.
I've been welding for many years and have never owned a set of mig pliers but then I don't tend to muck up my guns like some folks I've seen do. :lol:
plinker
Northern Wi
Where they've been handy for me was when there are several people at work using the same welders, not everyone cleans tips/replaces consumables when need be. It's quite annoying actually.
dr_clyde
Holland, MI
Same here and a piece of band saw blade ground down to scrape the spatter out of the inside of the nozzle.
If only there were a way to combine the two into a useful plier that workers could keep handy at the welding machine.
dr_clyde
Holland, MI
Those Bernard centre fire mig nozzles are tool less. I have only used them for hard wire. I haven't tried them for flux core or dual shield.
The center fire tips are tool-less, yes, but the Bernard nozzle is still threaded on. When you need to change a tip and the nozzle is screaming hot, the nozzle grabber section of the welper is nice to unthread the hot nozzle.
I have a Bernard gun on my 350p, those nozzles can get really hot running pulsed spray.
Steve_P
I have the Japanese welpers; they're fine. I bought them before Channellock made these or I wouldve just got the channellock; the welpers were a bit hard to source at the time.
