Channel locks are highly praised, $40 is to much for me. JMHO
Channel lock code blue.
Which grips are better?
Wherever feels better to you......
I prefer the non-code blue (top ones in your pictures)
Old pair of dykes with enough good spot on it to snip welding wire.
Am i the only one that doesn't use them? A quality pair of dikes will loosen the tip and snip the wire..
So "Code Blue" refers to the bigger thicker grips?
I've been welding for many years and have never owned a set of mig pliers but then I don't tend to muck up my guns like some folks I've seen do.![]()
A quality pair of dikes will losen the tip and snip the wire..
Same here and a piece of band saw blade ground down to scrape the spatter out of the inside of the nozzle.
If only there were a way to combine the two into a useful plier that workers could keep handy at the welding machine.
Add in a way to remove stubborn tips and nozzles and you'd have quite a tool.![]()
Those Bernard centre fire mig nozzles are tool less. I have only used them for hard wire. I haven't tried them for flux core or dual shield.
