Ok - now for a long overdue post. I've been putting it off because I didn't want to dig through my old pictures. This weekend, I finally finished a long overdue project (mostly
I've been renovating our living room for almost 2 years now. I did a solid 3 months of work, then the weather got nice and I moved outside. Then when winter set in, I got it mostly finished. Rinse, wash, repeat. I've been at about 98% complete for 8 months now.
All I needed to do was build some doors for the built-ins I built. In my defense, we were going to do glass panels in the doors and COVID put a hamper on that. I finally had enough and decided it needed to get finished. No progress pictures but the little guy and I headed down to the basement and got some doors built. I ended up using 1/4" mdf for the panels since it should be pretty stable and paints up nicely.
Completed room:
For comparison, the picture from the listing when we bought the house:
I do have a few progress pics and will give some highlights of the process. First up was scraping the popcorn ceiling. That was fun...not. Next was adding a ceiling fan and recessed lighting. This room had no lights before. Not even a switched outlet. Next was getting rid of the standard mantle and surround. What should have been a simple task was quickly complicated.
The surround was attached with adhesive. Couple that with the fact that there were no ties holding the brick back to the CMU and the brick came down. That was detour 1. On the bright side, I got to practice my brickwork.
Next was a new mantle. We wanted something rustic. I was lucky enough to get a tree from my parents property. My dad and I milled it with an Alaskan sawmill and then I used a router sled to plane it and true it up.
Next up with was the nerve wrecking part...for my wife anyways. I knew we had a chase to the left of the chimney and a closet on the right. Time to open things up.
Adding the base cabinets for the built ins.
Then adding the bookcases, trim, shiplap, and starting to install the built up crown molding.
New floor starting to go in here. You can also see SWMBO's one contributions - the whitewash on the brick. I actually think the technique she used was call a German Schmear. I'll give her credit since she doesn't read this, it came out really nice.
After that, it was lots of trim details. At this point, the only thing left is making a custom plate to cover the outlet I recessed in the mantle. I need to think on that a bit so I'll call it done for now.
Still using the same technique for posting pics which seems to work sporadically. In case this is one of those times it isn't working, pics are also attached. I couldn't attach them all but you should get the gist.
