So I am acquiring a Bridgeport Series II mill. I have been looking/wanting one for awhile, and although I was only looking at the Series I machines, this one happens to be free...
From reading the Series I weighs ~2200 lbs, the Series II ~5500 lbs. My problem is, I want this thing to be mobile, about as mobile as you can expect 5500 lbs to be.
I built a rolling base for my 20" Rockwell Delta Bandsaw that works quite well. I built it from 1/8" (I think) angle iron I had laying around. I then offset the casters to make the whole thing sit only about 1/2" off the ground...It works very well, it also only weighs ~700 lbs....
So what type of material should I be looking at to make something capable here? 1/4"? Angle or boxed? I've seen some casters rated at more than 3000 lbs per wheel, so that shouldn't be a problem...
Now one other thing i've been considering and seen done, since I wont be moving this thing that often, is to build a HD pallet from 4x4's and 2x4's, then use a pallet jack to move it whenever needed. I would have to borrow a pallet jack, but it wouldnt be that big of deal...The pallet idea sounds better for my VCT Floor...LoL...
Thoughts or ideas?
Thoughts or ideas?
