If you respect the limits and can live with a few thousandths tolerance, they're OK for home shop use. The bed on that one does look especially short though.
I'm surprised that the 3 in 1's are getting good reviews here. I had one and hated it. It was a great lathe but an absolutely horrible mill. The mill head was not very rigid causing all sorts of chatter when cutting parts. It also had very litte room between the milling spindle and the table where you clamped your part. You could not put a drill chuck and a normal size drill in the thing and drill a part that was more than an inch or two tall. There just wasn't enough room. I would suggest getting a seperate mill and lathe. $850 is also high price. You can get them new for not much more. I typically see them going around here for $300 to $500.
Keith
Honestly for $850, I would be looking at something else. Yes they are capable when used within their limited capacities, but so limited compared to other machines. I can't imagine making motorcycle parts on it. Model engine parts, yes, but not motorcycle parts.
I have always said that a 3 in 1 is bad at three things, milling, turning and drilling. For $850 it better come with a lot of tooling. If you raised your budget to ~$1200 you could most likely find a nice older bridgeport m head or a more robust table mill that would be light years ahead of that 3 in one. I saw where a guy converted a table top mill to CNC and used it to make really nice triple clamps, rather commercially I might add.
What do you have now, a lathe, drill press?
Hard to see in the pics, but I just want to mention. Never try to hold a end mill in a drill chuck.
If I couldnt find a Smithy, is the Grizzly priced at about 2000.00 ok?
I was always told the chucks were the weak link,dont know , just asking.
the key for professional and precise cuts is a machine that is built as rigid and heavy as possible when it comes to lathes and milling machines. you will soon discover that the whole design of this machine is not rigid enough at all.
Keep in mind, the machine buy in is just the start, and a 1/3 or less of what you will spend after just a few years collecting tooling, fixtures, work holding stuff.
Haaa, lots of lack of skill talking **** about what they can not do with a machine..
Love it..
To each his own, lack of skill on a better machine does not make a machinist..
Some can fool them selves all they want, others understand it's poor technique, tool selection, set up that results in a crappy outcome...
Way to many of us produce things that are to spec, on size, with great finish to say otherwise.
If many can get good results, the few that can not,,,, it's not the machine..
Gapfast-- When you say this is your first entrance into machining, do you mean, you first attempt ever? or you've had some maching experience and this is your first to get some machining equipment at home?
If you've never machined anything before, I would recommend taking a machine class from a local community college. This would be a cheap way to get all the basics and get a good foundation. You would also find out if you really like maching or not.
If you already have some machining experience, then I would agree with others to get two separate machines and a bit larger, space and money permitting.
This will be my first experience with it at all.
The tool wouldn't get used daily, but I would like to play around with it.
I see where your coming from.
Thanks for all the opinions
