Miller xmt304 questions
barnumflight
So I have a chance to buy a nice shape xmt 304 from a neighbor who is moving at a very very good price. It does not come with a wire feeder. Do I have any other options then getting a 22a feeder at over a grand? This is for my own personal shop. 06c0f8fe463e435aac15f385f1da084a.jpg
Sent from my Pixel using Tapatalk
Milton Shaw
You can use the 8 or 12 RC feeder with the control cables to get full remote control at the work site. Those are sometimes available on Ebay where I found mine with a 400 amp new Benard Gun. I paid $800 for mine that even has remote display's . It will also do scratch start DC tig and stick welding with the right hookups. They are a multi mode machine that works very well.
MJD1
Any Miller feeder with a 14 pin connector will work, 22A, 74 and several others. A suitcase remote control like a S22p12, 8 RC or 12rc will work. Suitcase voltage sense like a Miller S 32 p12, 8 vs or 12vs , or Lincoln ln-25 will work and be your easiest hookup. On the XMT you have a MIG setting for a remote control or a MIG vs setting on the function switch.
dr_clyde
Holland, MI
The XMT is an outstanding welder. If the welder is priced right, get it.
It is not too difficult to find a feeder for under a grand.
MikeF
I'd like to get one with arcreach, we ended up with a 12vs arc reach unit but our bobcats can only run it as a vs unit. ***** walking all the way back to the power source to make an adjustment or fine tune things
Attackcammel
The new arcreach is an awesome feature should of came out a long time ago it saves a ton of time. I'd love to find an xmt at a good price congrats
barnumflight
Well I got it. 700 with the homemade cart. Now to snag a wire feeder.d317b74e264947af3868480dd0e184d8.jpg
earthmover1980
South West Michigan
Miller inverter welders have an awesome arc! I have a maxtron 450 setup with a s22a feeder and stick weld leads. They weld very smooth and powerful. The stick welds are easy to start and just look great! I would definitely recommend the setup you have with a feeder on it. More versatile, with the best overall performance! I would suggest the wire feeder with 4 drive rolls, since they feed the best. The s22a is a little cheaper but works good too. Here is my setup!
signcrafter
I have the same xmt and picked up a miller s64 off ebay back around 2005 for 3-400 bucks. Back when you could find all kinds of good deals. Think it came from a shop and had to put new rollers in it and some other stuff but it works great. Think it needs a new gun, think the liner worn out but I don't weld much so for now it works. I also bought a miller spool gun for it but never bought the gas and got it hooked up. If I remember right the only thing the xmt can't do is stainless and I got the spool gun to do that and aluminum. I could be off on this, like I said I don't weld often. I just ran into the deals so picked up the stuff and have it if I ever need it.
barnumflight
Just wanted to give an update. Ended up snagging a wire feeder off CL last year (300 bucks) and finally got it all wired up in the shop. THIS THING IS A BEAST. Both stick and wire have great control.
96rjhtlT7ZKPk2nItO_kkpYHsQg1b0AxW3bRV_F5ANsPn0e3vMhKzSnSO_tI2C06_om4SQr0wS7Dk_XdgomwRLjG3WVEUlEh_9GuXJHADI25J3JBfWleftPaAPc6q51tkjcJCRMY2StFvojTtaI1dRcWBWWDmirva2HEKWJOzhXUIla9w6XWoJ1lBeaYKcwGXb0rS6NK_i9gikXclvJVPGXSHRKQty-gC-krZ8Ft8fBLj90J4pBgJorhswuL7JJkJkcBUiX1imAUtW-wvfHH23FAEGX8RDzmWkPEXlHHef1Uab14zThUPquBuPbvPcv-vIZNA9r-10nwgCn6t59sDKG4v-EyLq0Q-KdWijI6Umh3eu01ZrdqFCElzbIfIjxC87ev-XeYRLMk-ab88OhoGYpJYThcr2IdXfGSA_0tSik8A_jG2LGw2CgIzlaJ0wIuPi6evkFQoUQWqNFX-zIBKO2FDuq66c1wwzmwbkwargQnUxdJyZUfcZOcPZBmK5blFxjJLiYKMwwJfoVlSzmBg2q1MQHnFAtJYVKc_S_bj8OxbrP8uqYL6FnidHkMlivzdK_Tx1DHNzxqGGpYyqJE9pBIffVR9MV6dECRPuM76Cly9E4sNGr4LCzD8Eo0I8meiDHD5MobABJLQNSc4KV8clTFiOkVniuI=w522-h694-no
