Millermatic 211
99raptor
Anyone have any experience with the Millermatic 211?Did you buy it new?What was the cost?Brouchure I read said it could weld 3/8" steel on a single pass--True or False??
Zeke
I have welded with a MM 211 on 120v only. Nice machine. The literature says it will weld 3/8ths but the duty cycle is gonna be like 20%. If you need to weld a lot of 3/8 or even 1/4, buy a bigger unit with a decent duty cycle. Just my .02.
rsanter
visalia ca
I love my 211 and I can tell you that machine has some punch.
I think it would have no problem with 3/8 material
Bought new on promo at an event for just under $1000
Bob
kts
MD
I also love my 211. I paid a bit under $1k. I have only used it on smaller gauges so I can't talk about it and 3/8"
RatchetMan
I enjoy mine. I haven't welded anything thick yet but even on 120 volts it does a nice job. My dad has a cheapo mig welder and there's a big difference in weld quality. When it comes to welders, get a good one. Miller is a great company to buy from.
dr_clyde
Holland, MI
The 211 would not be my first choice for 1/4" and thicker. Can it do it? Yes. It will require perfect joint prep on clean metal with 240v input on a large breaker and .035 wire. And only 20% duty cycle.
I like my 211 a lot. It's my go to for 1/8" wall tube and general here and there fab. But it's not intended for large welding jobs. If I could only have one MIG welder, I'd have a MM 350P. Since I understand that's not reasonable for most folks, I'd have a MM 252. If you are just welding sheet metal and various brackets and such, get the 211. They are good little welders if you understand their limits.
sberry
Brethren, Michigan
It was made for guys asking about it on this forum. They had your pic on the wall as a poster child customer when they designed it.
zkling
It is a very attractive solid unit. Can it run 3/8" mild steel in a single pass, sure. Would it be a good machine if all you planed on doing was 3/8" day in day out, no. What do you plan on welding? Miller is a very reputable company they won't put out B.S. specs so no need to worry about the 7hp 110v air compressor. :lol:
Mxjr12
Green Bay, Wi
I hAve one I bought used for 250 and use it every day in my body shop and has no problems welding up to 3/16 on 120 and it is a beast on 220 and has no issues with 3/8
moopa
Nanaimo, BC
I bought mine in Canada for $1015.00, the best price I was able to find in the last year or so....and I love it. Haven't tried 3/8' yet, but if that's all you will weld, go for the 252.
Mark
add2255
I have one I bought it at air gas for 950 a year or two ago it has been the best welder I have welded lots of 1/4 plate with it on 110 and 220 I could weld 3/8 in one pass on 220 no doubt and the auto set is awsome I love this welder hands down if mine quit I would buy another
