TTMotorsports
Ok so I have this vevor 6" milling vise on my bridgeport. I mainly use it as a drill press. My old mill the jaw's of the vice had a 3/16" deep 1/8" wide step on the top edge, which made clamping flat sheet metal parts into it to drill and not worry about hitting the base of the vise. I want the same style jaws for this vise. I tried to machine a step it the vise jaws on the mill but the vise material is harder than my HSS Mill. If I can't find any I'll just draw a pair up on solidworks and have a local machine shop make them for me, but buying some already made will be cheaper/easier.
www.vevor.com
Right now I have some machining parallel's taped onto the vise jaws and it works but when I want to clamp something in to mill it I have to remove them before use and I'd like to have the step jaw's be permanently part of the Vise.
Any leads or suggestions on what I should/can do here.
VEVOR 6 Inch ACCU Lock Down Vise Precision Milling Vice 6 Inch Jaw Width Drill Press Vise Milling Drilling Machine Bench Clamp Clamping Vice (6\'\') | VEVOR US
VEVOR Precision Milling Vise offers a tough cast iron body, 45# steel jaws, 29 kN clamping force, and high accuracy screw for precise and durable performance.
