Milwaukee battery hard to install and remove
superduty1
I have a few tools in the M18 lineup. I have found that some of the batteries are difficult to install/remove. I have not taken the time to figure out exactly where the problems lie, but one example is an M18 Red Lithium 5.0 XC and sliding it on and off the Fan 0886-20. It does not slide on smooth. There is excess friction / interference making it difficult to remove and install.
My Fuel drill and driver both seem fine with the batteries I have. I am pretty sure my Sawzall has an issue with a couple batteries as well.
Was there a running design change to the either the batteries or the tools in the "rails" that the batteries slide on?
dnschmidt
Phoenix, AZ
No, it's a fairly common issue. My M18 turbo vac (the one with the round canister) has this issue with some of my M18 batteries. I have at least 20 M18 batteries so I don't care as I'll just use one that fits that tool better. You're not going crazy I just think it's a tolerance issue.
DFB
Southern VT/Western Mass
What screws are you referring to?
Sent from my SM-G973U using Tapatalk
The ones holding the tool body together nearest the battery. I have had a similar problem numerous times over the years though mostly with batteries designs that slide up into the handle, my old Makita was the worst but I have struggled with newer Milwaukee M12 in particular.
Rereading closer the fan is your major issue I see and just looking closer at mine right now I see that is molded and not centered on the case halfs like most of hand held power tools including the sawzall so my suggestion most likely wont help out there.
Sugarfryz
strange, mine fit in so loosely, it feels like its almost always going to fall out
donthelegend
St. Louis, MO
I have the same issue with my fan... 10 or so M18 batteries in various sizes, some are worse than others but the fan is the only tool Ive had an issue with.
I've just been ignoring it but it kinda sounds like it might be a more common issue than I thought.
Sent from my Moto G (5) Plus using Tapatalk
bp460
Chicagoland
I have sprayed the sliding surfaces of my M18 batteries with some silicone spray and it makes a big difference. Be aware that silicone can cause big problems if you do any sort of automotive painting or wood finishing.
-Brad
