I've got an older hole saw kit and was drilling some sheet metal and broke two pilot bits before finishing the job probably because I did not stay perfectly perpendicular to the material
The bits that come in the kit are high speed steel and run about $10
www.milwaukeetool.com
Milwaukee also has a carbide tipped bit that runs about $3
I mostly use the kit for wood and thin metal
Is the HSS bit worth 3 times the price for my purposes or should I refill the kit with carbide tipped bits?
High Speed Steel Pilot Bit 1/4" x 4" | Milwaukee Tool
Milwaukee Thunderbolt pilot bits are designed for extreme durability and long life. The Thunderbolt web features a thicker core than a standard pilot bit, which provides ultimate strength and protects against side-load breakage. A specially designed parabolic flute form clears chips and debris...
1/4" x 4" Carbide Tipped Pilot Bit
Milwaukee carbide tipped pilot bits are designed for long life in abrasive materials. Use for drilling fiberglass, brick, block and tile. Tungsten carbide tipped for extreme durability. Features a 3-flat shank that won't slip in arbor or chuck.
