Milwaukee is apparently going to do the right thing.
gearhead1
NC
Mistakes are made. That doesn’t bother me. Not owning them bothers me…..a lot. Only new car I bought ended up having multiple issues from the start and the dealerships acted like it was my problem. Never bought another car from that manufacturer ever. All I wanted was it fixed, but they wouldn’t do it. I had no problem with the defects, but the lack of ownership cost them my business.
Owning of this issue only draws me closer to Milwaukee. I don’t care a mistake was made, just own it and make it right. That is key to a good company and I will continue to buy their products.
ItsNemo
Canada
Theyre handling it perfect. Hats off to Milwaukee
Nope, handling it perfect would be recalling and replacing all of them.
Also, they could have not screwed up in the first place....this just doesn't give them a pass in my books.
scooby074
Nova Scotia
I agree they should never have left the plant, but honestly what theyre doing is essentially a recall.
dchawk81
They are pulling stock, they are allowing replacements of failed ones under warranty, they ARE NOT recalling them all which would say anyone with a B, please send it back immediately to get an A.
Pretty sure they did say bring your B in to exchange for an A.
4xdog
Santa Fe, NM
Only if it has failed though...
That's not how I read it, @ItsNemo.
"If users are experiencing an issue, they are encouraged to send their tool in for repair or replacement by utilizing our eService portal - http://bit.ly/2cwwBwJ. All products with the “H96B” distinction on the serial code will be replaced with “H96A”."
ItsNemo
Canada
Uh ... "If users are experiencing an issue" aka failed.
Bubba Fett
Eastern NC
Milwaukee is doing the right thing.
I'm thinking the reason they are not issuing a full blown recall is because they believe that not all of them are experiencing the problem. Indeed, some people apparently have been using the B version without issue thus far.
They want to replace the known bad ones first, to help customers that have been let down. Then they will deal with the others, including unsold stock. It wouldn't be fair to recall and replace ones in stores that have not been sold, while users have bad ones. This is why they think they can get the affected ones switched by November.
I'm guessing a full recall will follow, since they are reverting back to the A version, and will need to produce enough stock to make that happen. My guess is they also want to inspect the bad ones first and figure out what the actual problem is, or if there are multiple issues that could affect other products (i.e. shared components).
Realistically, this is the best response we could expect.
Mr_B
Reading
I wouldn't say 100% the right thing, they only doing this after online outcry/evidence and some relevant failure numbers make them panic a bit.
You best not forgetting there was a motive for this design and it was nothing to do with "nothing but heavy duty" Milwaukee slogan or consumer benefit in any way, it purely an effort to simplify manufacture design of something that had been deemed as perhaps excessive durability with room to cut costs for more profit potential .
If these changes been done improve power or reduce retail pricing it be more forgivable but it most certainly wasn't .
The 100% right thing would be allow anyone who purchased a B model exchange it for an A regardless of fact of failure/faulty as you purchased a tool that not matching what marketed or meeting the high standards of nothing but heavy duty.
If I was working in the field this tool be total liability with risk of crapping out at any time, that would be total ballache & you would want the A model as that the quality you been expecting ...
Madjik Man
Nice damage control.
Of course it begs the question: what would their response have been if they weren’t so publicly called out?
ItsNemo
Canada
My issue is, say, I don’t trust the B version.
Where does that not count? You’re projecting your definitions onto Milwaukee’s words, @ItsNemo.
You're projecting your fanboyism onto Milwaukee's words.
Experiencing an issue means the tool is not currently performing to specification, as per pretty much every single warranty on any brands tools in all of time. Would you expect them to warranty a tool because you feel like it's too heavy to hold all day too? lol
M635_Guy
NC
Im more impressed with the fact that they got caught with their pants down and everyone is letting them off the hook with a pat on the back.
:wtf:
An honest mistake is one thing. A dishonest one on the other hand...carry on fanboys.
:ROFLMAO: :ROFLMAO: How is it dishonest?
dchawk81
Like I said, it seems to break easily so go find something to break it on if you think they won't just take it back.
f121
UK
Do you own the B version? If so, use it until either it fails and you can return it to get the A version, or it doesn’t fail and you can trust it.
dr_clyde
Holland, MI
I’m no fanboy but it’s pretty clear they’re allowing a replacement for pretty much any reason. They may not even need you to specify a reason.
A recall is typically reserved for safety issue or some sort of legal liability. It’s possible using the word “recall” has legal ramifications, I don’t know I’m not a lawyer.
If you have ANY issues you get a full replacement no questions asked, and they’re pulling stock from shelves. If you have one of the B models and it works, you can keep it and use it. If you want to trade it in, you can do so and they’re not going to question it.
I see zero issues with this.
jayemm
up high down low
An intermittent switch problem should be a valid reason even if it doesn't happen at the time you return it. Who wants to be stranded on a job in the field. One needs confidence in reliability of their tools. The problems weren't just pin failures.
dchawk81
Trust issues are also an issue. Take it back "because I can't have it fail on me when I need it most."
D
dnschmidt
Phoenix, AZ
:wtf:
A legit point of view. If Torque had not pulled their pants down they likely would have gotten away with it. But, considering how easily they could have weaseled out of it by simply referring to their warrantee (like they did in their initial response) their modified response is better than expected I believe.
anndel
Hawaii, USA
Both spot on. Sorry couldn't get knurlednut's quote in here but spot on. I wondered if TTC didn't go on the air and others on You Tube, Milwaukee would try to see if they could get away with it?
dchawk81
Probably.
