Milwaukee Power Tools Deal Permathread
GForceJunky
https://www.garagejournal.com/forum/showpost.php?p=8783737&postcount=5085
Looks like the 12.0Ah is $219, 8.0Ah is $199.
Add up:
(original price of "must buy" item) + (original price of "free" item) = (big number)
Now find the ratio or percentage:
(original price of "must buy" item) / (big number) = (ratio)
Return value for each is:
(ratio) x (original price of "must buy" item)
(ratio) x (original price of "free" item)
If the promo is buy 8.0Ah battery get ... free then the calc is:
199 + 219 = 418
199 / 418 = 0.4761
0.4761 x 199 = $94.74 for the 8.0Ah return value
0.4761 x 219 = $104.27 for the 12.0Ah
If the promo is buy ... get 8.0Ah battery free then the calc is:
219 + 199 = 418
199 / 418 = 0.5239
0.5239 x 199 = $104.26 for the 8.0Ah return value
0.5239 x 219 = $114.73 for the 12.0Ah
Thanks for typing it out for me! ~$115 isn't bad for the 12.0. I mean, $219 isn't either, though Grainger had the pair for $209 for a while until a day or two ago. Really want to try a 12.0 out (have all the other sizes) but hard to justify when I have so many batteries already. Would be nice for the leaf blower/yard tools though!
TTMotorsports
Lucerne Valley, CA
I have a 12.0 and it lasts forever but is quite a bit heavier than the 5.0s . I actually had my 12.0 for over a year and it wouldn't take a charge so I had it fixed under warranty
luv2xlr8
Mobile, Al
Are they using separate SKUs for any of these deals? A while back I did the M12 Installation kit and the 3/8 ratchet for free, and it didnt ring up as free. The guy had to go back and get a different 3/8 ratchet with a different SKU for it to work. :dunno:
Not that I know of. I just grabbed an employee and asked him to get the brad nailer and then told him I wanted a 8.0 battery out of the cage and he just grabbed both from the normal stock location.
jherm
Possible you had a fuel ratchet that needed to be swapped for a standard??
ThatSickRip
Nope, it was the standard 3/8. The guy checked and said you need this one for the free one. Both rang up as same price, but the one he got changed after for the BoGo
Rusty67
LA, CA
It happens, sometimes they change the SKUs on the box. Happened to me with the inflator and they couldn't get it to ring up for me.
BroncoAZ
Maybe a deal at Tooltopia, not sure if it’s good enough for me to buy as I think my angle grinder can do most of the same cuts as the 3” cutoff tool. 2522 3” cutoff tool kit with 4.0 battery and two free 3.0 batteries for $199. I could use the 3.0 batteries on my M12 inflators I leave in the cars. Looks like the 3.0 batteries are $40 each on ebay.
https://www.tooltopia.com/Milwaukee-MLW252221XC
thepipe
Southern NJ
This cutoff tool is not even remotely comparable with an angle grinder. This is designed for more precise but MUCH lighter duty work than an angle grinder. I have both tools and there is virtually no "crossover" between them. It's not a bad deal, though, with all the batteries figured in.
BroncoAZ
Which would be better for cutting rusted ubolts on a trailer or 1/2” mooring chain links on the deck of the boat? I have plenty of other cutting tools, but my 3” cutoff tool is air not M12. I do have the M12 angle grinder and have seen some mounting cutting disks on those.
thepipe
Southern NJ
IMO, the angle grinder. This is not only because of its increased power, but also the form factor. The cutoff tool can be likened to a fist; the angle grinder more like your arm and hand with the fingers extended. The latter can be manipulated to get into more areas. Besides, for the tasks you mentioned you don't need the precision offered by the cutoff.
danny_barkley
FL
You guys are talking about the Right Angle Die Grinder, right?
danny_barkley
FL
No. His link - and the topic AFAIK - is the compact 3-inch cutoff tool model 2522. Think mini (VERY mini) circular saw.
He/They mention the cutoff saw and the "Angle" Grinder. When I hear angle grinder, I think Angle grinder, not die grinder.
When he says angle grinder, is he referring to the Right Angle Die Grinder? That was my question.
shteii01
Indiana, USA
the small m12 bandsaw is probably the way to go: 2429-20
will335i
IL
I am really impressed with how well the mini bandsaw cuts. I was cutting up some 1/4" box tube and it went through it so smoothly. That's even with the junk blade it came with.
My two complaints would be a increased cutting area and the ability to lock the switch in on. I am sure that second point is a safety issue.
techieman33
Kansas
My portaband experience is an older beat to **** Dewalt so a good one may not be as bad. But one wrong twitch and it'll throw the blade off. And every now and then it seems to come off on it's own. But if the blade comes off and the switch is locked on it could bend the blade up, or maybe jam it in to something.
PugetDude
Superstition Mountains, AZ
Either one will do the job. I'd go for the one that you least care about dropping overboard. :lol_hitti
toolin' around
Los Angeles, CA
What a confusing conversation!
Yes, there was some confusion over whether there was an M12 Angle grinder or an M12 RA die grinder, but the original question was assessing the M12 3” Cut Off tool.
I think the OP’a current inventory is:
M12 RA die grinder (yes, you can mount a cutting disk in it)
M18 Angle Grinder
Pneumatic 3” cut off tool
Someone also suggests the M12 portaband, which was not in the list of options...
For the two tasks specified, in order of preference (excluding the air tool), I’d go for:
Rusted 1/2” U bolts:
1. M18 angle grinder
2. M12 RA die grinder (only if access was limited for 1.)
3. M12 3” cutoff would be a distant third and only if I didn’t have 1. or 2.
4. M12 portaband - it would be a ***** to get a decent angle of attack, and would be a pain!
Deck chain:
Assuming it’s on a deck, and not secured in a bench vise...
1. M12 RA die grinder (less risk of severe kick back if you’re just holding in vise grips or similar)
2. M18 angle grinder (watch for kick back)
3. M12 3” cut off tool
4. I would not use the M12 portaband unless the chain was in a vise (or my M18 portaband on the SWAG table.)
Bottom line... the M12 Cutoff tool (IMHO) is not a better choice for the specified task than any of the tools the OP currently already owns.
BroncoAZ
M18 Angle Grinder
Deck chain:
You interpreted correctly. I agree that the M18 angle grinder is probably the best tool in my selection for the tasks at hand, so no need to buy the 3” cut off tool.
logixjock
Sturgeon, MO
M18 Angle Grinder
Deck chain:
So, I don't have the angle grinder, portaband, 3" cutoff, none of that stuff. What would be the best tool to cut off the rusty bed bolts on my Ford Ranger so I can get the fuel pump replaced? I'm thinking it isn't even worth digging out the impact as bad as they look. I have pretty much everything I might need in pneumatic or corded, but looking for an excuse to add to the Milwaukee stable.
Rusty67
LA, CA
I'd go with an angle grinder if I was going to cut it off but if they are rusty enough, maybe and impact will just sheer the bolts for you. Might be faster?
toolin' around
Los Angeles, CA
If you’re looking for a reason to buy a tool, I’d say the M18 Angle Grinder will give you the best general purpose tool once you’re done with the bed bolts.
But I’m falling in love with that M12 RA die grinder... it would be slower going on the bed bolts, but more precise... like a scalpel vs an axe!
Depends what else you do, and whether you have a preference for M18 or M12 platform.
jonshonda
Wisconsin
Looking at the M12 Surge Impact 2551-20, what kind of deals are out there for them typically? Hoping to bundle it with the larger 6.0 battery.
48548
Phoenix
That is what I was thinking... knowing my luck the nuts would round off.... I would get my torch out....
Sent from my SM-N975U using Tapatalk
ThatSickRip
They had a killer deal at HD maybe a month or so ago with the M12 Surge, 4.0 battery, charger and case for $129. Only reason I didnt grab it was because I had literally just got the M18 Surge
cajunfirehawk
Ms Gulf Coast
On the look out for a deal on this in bare tool, lowest I have seen is $324 plus $10 to ship plus tax, any deals on this yet?
Milwaukee 2745-20 M18 FUEL 30 Degree Framing Nailer
swaps
No real deals on the framing nailer yet. Home depot had the price mistake up for a couple hours a few weeks ago. Was 400 for M18 drill/driver kit and framing nailer.
TTMotorsports
Lucerne Valley, CA
I like home depot price errors. I got some stuff from them for 5.00 each instead of 50.00 each because of their mistake. Worked awesome for me and I made some money on that too selling it on Craigslist and the like.
jonshonda
Wisconsin
Profiting off of others mistakes seems like an honorable thing worth mentioning on a public forum.
pbon
I was thinking the same thing, but then realized I have gone through the register knowing that the price that rang up was or was probably wrong, and done nothing. I have also, more commonly now that I am in the 2nd half of my life, commented on a price that seemed incorrect. Maybe I am getting wiser or maybe I am getting foolish, but I am happier trying to do what is right rather than what I know is wrong.
logixjock
Sturgeon, MO
Actually this is the only M18 tool I own that I am dissatisfied with. Poor battery life with a 9ah battery and a funky trigger set up. Wouldn’t buy again
Thanks, that's good to know. I've been put off by the price on that one, I'd hate to find that out after I held my nose and paid what milwaukee thinks it's worth.
Odd-job
Was hoping they'd have it with the brand new M18 3/8" Stubby Impact. Just have the regular impact :(
Thanks for sharing!
Looks like it is included. Trying hard to convince myself I don’t “need” it. Best deal I have seen on these given they are new.
