AceofSpad3s
- Joined
- Oct 1, 2014
- Messages
- 1,808
I bought a 7x14 vevor mini lathe a while ago, haven't had the chance to actually set it up in a permanent way yet though. At first, it was because I couldn't find a good spot for it, and didn't have anything to mount it to. Well I remedied those, neither are particularly good though, I found probably the most beat to death Snap On late 70's 30" box on the curb for free which was a bit closer to banana than rectangle in shape and stuck it in the corner by the oil tank. I built a cradle for the bottom and have some leveling feet on it, so it's quite stable now. For a box the top is thicker than most in terms of gauge, but not ideal to mount a lathe to even ignoring that the box is a bit wonky.
I've seen people do cast concrete bases for the little import lathes to give them a heavy base to help stiffen them up, but with curing it would take a while to get that going, I might do it at a later date.
Would laminating 3-4 pieces of MDF to get a 1"-2" base be a decent solution to give it a stiff base at least to get it going to run small parts? Obviously not ideal being a wood product, but being engineered it would at least be far more stable than typical natural lumber with humidity shifts, not that the basement sees that drastic of a change compared to the garage.
Obviously the ideal would be mounting it to a thick steel or aluminum plate, but sourcing one that's 1" thick is going to cost half the price of the machine.
