Wileel
Title sums it up, but here is what I'm looking at and could use some thoughts or advice. I'm about to install a Mr Cool on my shop that has brick corners.
The inside unit will be going in the center of this back wall and I would like to put the heat pump on the wall that is on the rt side in this picture, just around the corner....if I have enough line. Question is how do I get the line set around the corner cleanly?
The way I see it I have a couple options...
1. Run it up from the heat pump and go into the attic space to the inside unit. Problem here is getting it back out of the attic and into the unit
2. Some how get it around the corner and then run up the back wall and thru it to the unit.
Any thoughts?
....and yes...that is a big a$$ lizard on the wall...
Any thoughts?
