Mini split vs. through wall unit
DanV58
Moline, Illinois
Hi, I’m looking for opinions on a mini split vs. a through the wall ac unit in my 24x30 garage. Garage is well insulated. Located in Moline, Illinois. Mostly looking for cooling. 18,000 BTU. What thoughts have you?
MattT
If you plan to cool 24/7 the mini split should save enough electricity to justify the additional cost if you buy & install it yourself. If you're going to have a pro furnish and install probably not worth it from a cost standpoint. Quiet is nice but maybe not $$$$ nice.
Also what, if anything, are you currently doing for heat?
SALIV8
chicago and s/w michigan
Mini split all the way. It's super quiet, super efficient, and only has a 2 1/2" -3" hole as opposed to a large one.
Get one that is ahri rated to qualify for rebates. ComEd is giving $400 back. Search it and follow their instructions.
You'll be able to find one of their installers to just do the flares, final evac and release. I did. And you'll also be setup for factory warranty. Not sure my guy would travel to Moline tho. Mr cool diy units also have a decent warranty but I don't think qualify for the additional rebate.
Actually the REAL benefit of a mini-split heat pump is heat. Even the cheap ones will heat down to about 35F. The good one will provide heat to below 0F.
MattT
How many mini splits do you own? And of those how many are retrofits replacing window shakers?
SALIV8
I would tend to disagree. Heat in low oat is definitely a good thing from a mini split heat pump, but the best efficiency is on the cooling side. Hands down.
D
DanV58
Moline, Illinois
I’ve got a Reznor gas fired ceiling mounted unit for heat. 0
Notgrownup
Snow Hill NC
I have a mini split 18000 btu in my shop, it’s a 18 seer and runs great and quiet.
I have a through the wall unit in my sunroom and hindsight 20/20 I should’ve done a min8 split, way more efficient.
mike93lx
Richmond, VA
Cost aside, mini split without a doubt.
I wouldn't go through the trouble of framing and trimming and opening for a through wall if one didn't exist already.
Bretny
Dutchess county NY
Just get a through the wall. You will spend half as much and that may take 10yrs to make a minisplit to just break even.
fasteddie
The only thing I've ever seen fail on a window or through wall unit is the control switches, when they had mechanical rotary knobs, otherwise they run forever. Split systems and central air units? well you can google the millions of repair and help questions about them.
nh_yota
Seacoast New Hampshire
Maybe the ones from 30+ years ago run forever...but you're lucky to get five years out of a newer one before the compressor dies or the system loses its refrigerant.
MattT
Mini split heat is generally about the same running cost as nat gas but substantially cheaper than propane. Varies somewhat with local prices and the gas heats efficiency. So if you're on propane using a mini to reduce your gas consumption should save some money. Might even be worth paying the premium for a hyper heat mini if you're on propane.
D
DanV58
Moline, Illinois
Reznor is natural gas. Works like a charm. Just didn’t plan on having AC until.
To answer another question, my AC usage would be several times a week, but not running constantly. I would use it like a window AC, only on when in the garage. Leaning towards mini split becuz I don’t want to cut a hole in my garage wall. Currently don’t have a window in the garage. TIA for all the input folks
Yankeefarmer
Connecticut
After being unable to work in my 28x28 shop for too many days last summer due to the heat and humidity, I installed a Mr Cool Advantage 18k this past spring. My building is mostly 2x4 construction with less than 1/2 the walls insulated. It does have a full ceiling with 6” fiberglass insulation. There is only one small south facing window, so little solar gain. I had considered a larger unit for better heating performance, but already had a propane furnace and wood stove for heat. The Mr Cool has maintained my shop comfortably cool on several 90 degree plus humid days without seeming to work hard at all, so I am delighted. We live in north central Connecticut near the Mass border.
I had initially considered the Mr Cool DIY, but didn’t like the idea of extra line set coiled up and decided to roll the dice regarding warranty. After plumbing it, I did a 24 hour leak check by pressurizing it to 225 psig using C25 shielding gas before evacuating it per the manufacture’s instructions. My total outlay for vacuum pump, condenser stand, lineset cover, and mini-split was under $1200.
I also considered a through-wall unit, but was concerned about the noise level. The Mr Cool unit is practically silent.
dcg9381
Austin, TX
Doing a pressure test is definitely the way to go. Lots of people try to see if it will "hold" a vacuum, but it's easier to see if it holds 100+ psi of pressure.. if not, a little soap and water finds the leaks.
Metalcrafter
Jacksonville, Fl
I live in north Florida and have a metal garage (26 x 40 x 12) with insulated walls and ceiling. I installed a Mr Cool DIY mini split (24,000 BTU). I keep it at 79 degrees and turn it down to 75 degrees when I am working. It is the best investment that I made. It is so much nicer working on any project without sweating your tail off. The only hole through my wall is 3 inch diameter for the lines to run outside. My power bill runs about $45.00 per month during the summer.
LS6 Tommy
Northern NJ
Lots of opinions here based on owner use and nothing else. "Through the wall"... Do you mean a PTAC? They ****. A ductless mini split KILLS them in both comfort levels and efficiency. 1.5k won't properly conditon your space. You CANNOT properly leak check ANY HVAC system with vacuum...
Tommy
Notgrownup
Snow Hill NC
I have a PTAC in my sunroom, it works well but it’s not the most efficient at 14 seer...could be worse though.
iowa4x4dieselman
This may be, but also the cost of a window unit is cheaper, so many repairs are not performed, but rather units are tossed.
