DanV58
Hi, I’m looking for opinions on a mini split vs. a through the wall ac unit in my 24x30 garage. Garage is well insulated. Located in Moline, Illinois. Mostly looking for cooling. 18,000 BTU. What thoughts have you?
Actually the REAL benefit of a mini-split heat pump is heat. Even the cheap ones will heat down to about 35F. The good one will provide heat to below 0F.If you plan to cool 24/7 the mini split should save enough electricity to justify the additional cost if you buy & install it yourself.
If you plan to cool 24/7 the mini split should save enough electricity to justify the additional cost if you buy & install it yourself. If you're going to have a pro furnish and install probably not worth it from a cost standpoint. Quiet is nice but maybe not $$$$ nice.
Also what, if anything, are you currently doing for heat?
The only thing I've ever seen fail on a window or through wall unit is the control switches, when they had mechanical rotary knobs, otherwise they run forever. Split systems and central air units? well you can google the millions of repair and help questions about them.
I’ve got a Reznor gas fired ceiling mounted unit for heat. 0
Mini split heat is generally about the same running cost as nat gas but substantially cheaper than propane. Varies somewhat with local prices and the gas heats efficiency. So if you're on propane using a mini to reduce your gas consumption should save some money. Might even be worth paying the premium for a hyper heat mini if you're on propane.
