A little background... I have a 24x36 pole barn that I have put up stud walls on the perimeter and r-13 bat insulation. The top of the plates are 12 foot and the peak is about 14 foot. I still need to insulate (already have double bubble) the ceiling and plan to do that with vinyl backed insulation. My plan all along was to do a minisplit as they are efficient and more affordable than a full on HVAC system. There are no internal walls as it is open space and want to keep it that way. I have done the online calculators and determined for my shop I need a 18k BTU mini split. I started calling around to get bids and WOW am I floored by the pricing I have received...
First Bid was from our builder's guy who does his HVAC in his current builds.
2 Ton Mitsubishi mini split $3974.00
Second bid from a HVAC company
2 Ton Mitsubishi mini Split $4900.00
2 Ton Daikin Mini Split $4530.00
PTAC Was recomended to "Save on Costs" and he quoted me $2583.00 and that is if I do the electrical and cut the hole and build the frame (NO WAY!)
Third Bid from another HVAC Comany
2.5 ton Mitsubishi (his calculations not mine) $7200
2 Ton Lennox (he said they are a bit cheaper) $5900
I told all of them I am not set on a Mitsubishi and needed a lower bid.. they are not having that at all...
Looking online I see the pricing for the units and wow they are trying to smash a grand slam on a minisplit.
Hub
Hub
