Miraco | (399-5) Underground Shutoff Kit
manwithtools
Lebanon, TN
No experience with that, but seems expensive for what it is. Why not just use a PVC ball valve and fab up a tool to turn the handle? I use a piece of 1-1/2" PVC with a notch cut in the end to accept the ball valve handle.
930dreamer
Amarillo,TX and Stinnett,TX
I did install PCV valve between the two outdoor water lines. I know the one line going to the farm house leaks, no real idea where the valve is buried now. Hence thinking about the above ground base/cover for locating.
manwithtools
Lebanon, TN
I'd install the PVC Ball valve below ground, then install a piece of 4" PVC from the ground level to the valve, use the 1-1/2" PVC "tool" to operate the ball valve. The 4" PVC get's a female adapter and a screw in plug at ground level. Would do the same as that $400 valve for $25...
manwithtools
Lebanon, TN
@930dreamer Here are a couple of pictures of my "Shut-off Tool". It's actually made from 2" PVC, not 1-1/2" as I stated earlier. A hole in one end allows using a steel rod or socket extension in for more leverage if needed. The opposite end is notched to engage the ball valve wings. Works great.
yatg
Southern Oregon
Because PVC ball valves ****. Few years from now when he goes to turn the handle, the valve is stuck, the handle tabs snap off, and you're digging again. Have a couple of 2" on my irrig pump and they have each lost half the handle and are just about frozen and it takes a pipe wrench to turn them. Next time its gonna be genuine Chinese stainless.
The Miraco above is just a curb stop valve, and that's probably the type of valve you should use if you're going to bury it. You can buy or
make a custom key for it out of steel.
