bolensboneyard
Coming along nicely. It looks so square and plumb.
Does the floor have a drain, this is the first time I've seen the pvc pipe in the bottom left corner of the photo? Or is that for something else?
How do you plan to finish out the interior?
The pipe is to drain the pad around the pool area as the basin area is located in that area and I planned to build a fireplace into the front of the building. That was before I had to move the location of the window. The plan now is to extend a short wall out from the shed and turn the wall ninety degrees then build the FP. This will allow for a small, wind sheltered area to sit in the early winter.
I do not intend to finish out the interior. Beams and bricks a bench and my hand tools.
You have to be a craftsman to understand the quote
