Moderate deal on real Hylomar
doan
Frisco, TX
this is amazing stuff. the only thing I found that was completely fuel proof for sealing the gas tank sender on my old Austin Healey.
Also never dries, you can disassemble and reassemble without re-aplying.
The Permatex version is called:
Permatex 85420 Permashield Fuel Resistant Gasket Dressing & Sealant
Hustler388
I had bad luck/failure with this permashield, In a supercharger application it would let gas seap by and leak on the motor, maybe because of boost?
fyi
anyheck
New Orleans
This is where I've purchased Hylomar before once Permatex swapped over what they were putting in the tube. The prices seem competitive with this deal and there are other packaging options available.
http://www.silver-seal.com/category/shop.2_shop_essentials.hylomar_products/
If memory serves, permatex used to be Hylomar Advanced Formulation and they changed it to the Universal Blue the difference being that AF does not cure and has no solvents and UB does, I think just making the application of the UB a bit easier.
Squankum
Southeast
Here's the "some guy on internet" where I found an opinion about changes to Permatex's recipe for what they used to sell as Hylomar, and now just something like it. From amazon:
"4.0 out of 5 stars Compare to Hylomar, April 13, 2013
By Dave R. (Sacramento, CA) - See all my reviewsThis review is from: Permatex 85420 Permashield Fuel Resistant Gasket Dressing & Sealant, 2 oz Tube (Automotive)
I picked this up at a local store. I would have bought it here had the word HYLOMAR been in the item description. It's clearly written on the packaging "Compare to Hylomar".
The actual Hylomar stuff is hard to find in the USA lately. This being Permatex, is in theory available anywhere Permatex is sold which is almost everywhere.
For people used to the OLD Hylomar.. this new stuff has acetone in it and according to some online research, that means it's most similar to the Hylomar universal racing formula. As a result of that, it applies much differently than the old stuff which I think was called universal blue. The old stuff was like a gel and didn't get stuck when rubbing it on with fingers, however this new stuff is like gel/liquid and if you apply it thin, you will feel as if it's stuck and you're pulling it around rather than applying it.
I much preferred the old stuff, but this seems to work so far on intake gaskets."
