Modified lathe steady rest
OccupantRJ
Eastern North Carolina
I did not have a steady rest for my Clausing lathe, but I did have one that fit a lathe with a slightly smaller swing, so I decided to make a slight modification so I could use it. The bottom of the steady had a notch in it to seat onto one of the lathe bed ways, so I milled the base to get rid of it. After some measuring, a new adapter base was machined to be attached to the bottom of the steady rest to act as a riser, and also to center the 3 supports in proper relation to the lathe centerline. The results are pictured, minus a paint job..
larry_g
oregon
Kinda see what you mean. I just need a bit for cutting the V slot and some thick steel.
If you have a mill then you can cut the V with a standard bit if the IF it is not less than a 90* angle. If the V is a 90 then hold the part to be machined at 45* and make the cut with a regular cutting bit.
lg
no neat sig line
TheEquineFencer
Farmville, NC 27828
lg
no neat sig line
I thought about that...the idea of tilting my BP after the PITA it was to get it level to start with doesn't appeal...I need a big chunk of steel, about 2 inch thick to get the rest I have close to center.
stioc
SoCal
I think what larry_g means is this:
no need to tilt the head as long as the part can be held in a vise.
@OccupantRJ, nice work!
yaidunno
WI
Nice fix! I had to do similar with a 14" for my 15" lathe. Thanks for sharing.
matt_i
Cool! :thumbup:
I'm curious about the V-slot, I had to do a bedway-engaging plate once on a square head Clausing Colchester and ended up using a shaper for the V-slot, as it was an included-angle measurement outside of standard milling cutters.
Also, how did you determine the position of the steady on the bedway, rough-indicate the "ID" of the casting?
O
OccupantRJ
Cool! :thumbup:
I chucked a piece of larger tubing in the chuck and used the adjuster bolts to get it to a measured center. I used a horizontal style milling cutter in the Bridgeport to cut the slot in the plate, as the V slot was not 90 degrees.
On other projects in the past I have taken a dull circular dual angle milling cutter and reground it in a K.O. Lee tool and cutter grinder to the angle needed to do the job. I bought a bucket of old cutters at an auction to use as needed.
I have also made my own carbide tipped circular cutters in the past by slotting an old cutter to create gullets, then silver brazing carbide triangular inserts into them. A grind with a diamond wheel got it to the angles I wanted. Those cutters have cut millions of brass parts for years with a touch up every now and then.
