OccupantRJ
I did not have a steady rest for my Clausing lathe, but I did have one that fit a lathe with a slightly smaller swing, so I decided to make a slight modification so I could use it. The bottom of the steady had a notch in it to seat onto one of the lathe bed ways, so I milled the base to get rid of it. After some measuring, a new adapter base was machined to be attached to the bottom of the steady rest to act as a riser, and also to center the 3 supports in proper relation to the lathe centerline. The results are pictured, minus a paint job..
