Modified Post & Beam Garage Build
S
seth928
South Coast, Ma
think its way past time to update my progress....if anyone is still interested. I had to stop progress shortly after my last post...picked it up again in July, and have been getting a few days in here and there.....by the way Lyme disease kicks your ***...so be vigilant about protection if you work in tick environments. updated pics to follow
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Wow!!!!Very sorry to hear about the Lyme Disease. Hopefully all is well now. :thumbup:
As far as the barn goes, GREAT JOB!!! Looking forward to more pics of it. I wish I had enough trees around to do something like that. Once you're done, it will be a special place. To think it was trees from around the neighborhood, dropped and sliced, and now it's your barn. That has to give one a fantastic feeling right there. :beer:
S
seth928
South Coast, Ma
On a serious note...lyme *****. I knew ahead of time that with what i do it was only a matter of time....i am located in the hot zone for lyme carrying ticks in the continental US ...we use spray almost everyday, the problem was just that "almost every day" .....if u hunt, fish, hike, or just work in the woods........use a deterrent....every day!!!!
S
seth928
South Coast, Ma
some interior shots....work bench area...etc
S
seth928
South Coast, Ma
thank you SIGma....more interior shots
jlylec
Charlottesville, VA
seth this is awesome! i love the milled wood and how it's aging. just looks great. very impressive! how'd that loft landing pass inspection? that looks WAY dangerous!
your workbenches and everything are very well thought out and executed too. where would are you going to put the lift?
S
seth928
South Coast, Ma
Thank You :beer:
The landing isn't completed yet haha...I have to tie it into my collar ties and add a railing...hard to believe but the way its mounted now it doesn't move at all, its through bolted through the steel I Beam and also 3/8 by 6" angle iron on the 4 corners...but I agree it looks dangerous.
The lift...still working on the exact placement but it will depend greatly on what type I finally decide on...if its a fixed lift it will definitely go in back open bay, i have the room even with the stairs and platform but it again will be tight....should have built the whole thing 10' longer :sad: but that wasn't in the budget.
mwbailey
Rock Hill, SC
Seth, Glad to see the garage close (!!) to finished. Very impressive build. I, too, like the (very, in my case) modified P&B approach. Also like what you have done with left-over lumber for your benches.
Omphaloskeptic
Ultima Ratio, Wa.
"but then you realize all the nitty gritty......finishing the inside just scares me at this point "
Well, now that you have considerable experience under your belt, how are you feeling with your terrific project?
Loved the early on picture with the snow on the structure; is it time for another snow pic? You should feel very proud of the work you have done on a really great looking build! With exterior lights on at night and a fresh snowfall, your garage/property must look like a Currier & Ives picture postcard. I'm definitely on board for progress pics both inside and out.
1953mercury
Steamboat Springs CO
Very nice job. Are you planning on insulating and heat, or leave as is? Kind of a shame to cover that up. I did a modified post & beam on my house and really like the way it looks. Mike
S
seth928
South Coast, Ma
Thank You, I plan to have heat for sure, probably a Modine hanging heater...I also plan to insulate at least the roof and loft. I don't like the idea of covering it up either so I going to barn board over the insulation.:)
S
seth928
South Coast, Ma
Your build is very nice:thumbup: I was going to do something similar with hardware from a company that pre-frabricated the brackets but I chose this route instead....also saved me quite a few bucks!! I have way beyond exceeded my initial budget....sooo every little bit helps:headscrat
S
seth928
South Coast, Ma
Omp....honestly the feelings are mixed:headscrat....I like what I have accomplished:).....I do wish I did a few things differently:wtf:....and its still not completed:dunno:.....and more than likely I will be leaving it behind, we are probably going to relocate in 2-3 yrs:confused: .....but I told myself when I started, if we move, I'll just build another one!:willy_nil
Free Willie
Connecticut
Wow nice build! (I'm a little biased)
I really like the roll out work table - one of those wish I had done it that way things.
I insulated mine but still left the framing exposed for the looks.
It was a lot of work but well worth it. I thought I would only turn on the heat when working but found it wasn't that bad to keep it 55-60 all the time.
I will be checking in on this build, w/o the trespassing part. :thumbup:
Tarnished
SW Ohio
928: Awesome build! Looks great, just great! Really love the look of all the exposed beams and walls. Shame to cover it up just for HEAT! :sad: :lol: I like what you've done with your benches and shelves. Heavy Duty for sure. Will be there long after.....
Keep us updated! :beer:
