hellspcangel911
- Joined
- Jan 3, 2010
- Messages
- 237
Hi all,
I finally installed at setup my late 80s System 1 9,000 lift. Many refer to it as a "1 line" as it has only one hydraulic line overhead connecting the two posts. I did the proper bleed procedure as outlined in the manual. I got to step 7, ran the slave side carriage to the top and now I cant get it down. Yes, the safeties are completely released, there is nothing holding it up except for pressure.
I found this thread thats exactly the same issue, on a similar lift, but releasing the pressure from the overhead line did not work for me. It did "free up" the slave side carriage so i can move it 1/4" bouncing on the hydraulic ram.
www.garagejournal.com
When I press the power button now while both carriages are maxxed out, I can feel the spool valve release pressure when I pull on the lowering knob.
I tried calling Mohawk but they were already closed, will try again tomorrow but obviously was looking forward to getting it working and the garage cleaned up.
Help My Mohawk is stuck!
Just finished my install of a used system II 6000 lb two post and was running it thru a couple up and down cycles to equalize/bleed it. It was going really well but now it's stuck in the fully raised position and wont come down. No car on it of course. Any ideas?
