L5wolvesf
Sorry if these questions are a repeat, I’ve searched but come up with hundreds of compressor etc threads.
Need some input on some things I have read here re air line systems. First, my garage is 24 x 32, Craftsman portable 33g compressor. I will NOT be using PVC and I do not want to deal with any of the metal pipe options. The install would be a PITA with all that is in the garage now. The tubing will be routed along the bottom of the rafters and will tee to; a hose reel at roughly the mid point of the working area of the garage, and drop close to a small outside door where I can plug in an extension hose for outside needs. I will also be building a small media blast cabinet soon.
At this point I am leaning toward PEX because; affordable, ease of expansion, materials available locally (vs Rapidair, etc) at several places, ease of install.
My questions are:
One concern I have with Pex is it is rated at 100 psi at 180 degrees. My compressor can put out 150 psi.. How does 100 psi at 180 degrees translate in non-Hellish like temperatures?
Air cooling - I read on a piping layout diagram that a minimum of 25 ft to the first outlet is required to cool the air. My hose reel will be first (other than a plug in at the compressor) at about 12 ft, then the exterior plug in at about 30 ft. How do I deal with the cooling issue, or is it not really an issue?
Dryer and filter. Are either/both needed on a small system? Can I put them in line just after the compressor?
BTW, this is an XLNT forum.
Thank you,
L
My questions are:
Thank you,
L
