Most compact 1/2” right angle drill?
sparky 1971
Central Iowa
The M18 hole hawk like the OP posted offers a version with a clutch, which I have. It’s very nice on the body part’s being smashed when the bit catches.
It doesn't have a clutch that slips like the old drills did. It shuts down way too easily when it gets bound up, but I don't think the hole hawg has enough balls to smash anything if it didn't have that feature. The Super Hawg on low could be another story, but even with a 6-3/8 hole saw through 3/4 plywood I don't have a problem with it twisting on my when it gets in a bind. Maybe it's because of my superhuman strength that I can hang on to the drill and force it the other direction. I have the Rigid version of a corded hole hawg with a three speed transmission. That has a clutch that slips, but only when it's in 1st gear. It kinda takes the fun out of drilling big holes.
Back in the late 80s, buddy told a story of job site apprentice electrician drilling holes between studs with a Hole Hawg. Supposedly the spade bit caught onto something, lifted the apprentice off the ground, and broke a rib when it slipped out of his grip.
Dunno the truth, but I'm very wary with them.
sparky 1971
Central Iowa
The old drills were like that. A shop I used to work for in the mid 90's had some Hole Hawgs that made for fun times when they would grab a nail in the top plate. I was always able to hold on and a couple of times when the bit came out the nail would be wrapped around the auger bit. I have a corded pistol grip Black and Decker from the 70's for nostalgia purposes that I won't use for anything tough because it's missing the side handle and the handle that is there is small enough that I can only get three fingers on it. It's the only thing that has ever been able to twist my wrist around. I bought my M18 Hole Hawg the day it was released for sale. It has performed flawlessly, but it's underwhelming in the power department to say the least. I was trying to run a 4-1/4" hole saw through a rim joist and it kept shutting down so I went and bought the M18 Super Hawg. It's much better power wise, but still nothing compared to a corded drill in the same class.
Zewnten
Yeah mines the super hawg, forgot it was a different name. I’m usually drilling in confined spaces with lots of sharp objects so any binding ***** quickly
Retired dozer fixer
Leesburg Indiana
We did have that once where an electrician was drilling into the main cabinet with an 3 x100A 3 phase supply which was live and the shavings shorted out all 3 phases and blew all 3 main fuses, the utility was not impressed with that one.
Why in the world would anyone in their right mind be drilling in a hot cabinet to start with?? How’s that working for you 🤬
KnurledNut
n/a
@sparky 1971 @RTM @others
Ive had my **** handed to me a few times by the OG corded hole hawg. I think I broke my jaw once, but never got it checked.
Tore my wrist to bits with a bound up Makita.
Had an old Milwaukee beast hammer drill go AWOL when drilling 4-1/4” through siding, sheathing, and rim after deciding it was a good idea to lock the trigger on...haha...smokeshow.
Once had a old heavy metal air drill with hole saw attached fall out of a ceiling I was demoing and bust my head. It was left there and forever lost by the original builders during installation. I didnt know what was attacking me at first.
I share the sentiments.
:lol:
BreeStephany
Oregon
I've had to drill into live switchgear cabinets before, but ALWAYS take proper precautions like adding a proper rated voltage blanket / line blanket to cover exposed bussing, wearing proper PPE because no one wants to live through an arc flash without it, and when drilling steel cabinets, I put a rare earth magnet where I'm drilling to catch the majority of shavings and to catch the metal "plug" before it falls anywhere.
I've seen my fair share of sketchy hot work and know people who have lived through arc flashes... its not something I EVER take lightly and take every precaution I can.
I once had to retorque and repair damaged line side bussing on a switchgear and the customer told me there was no way they could loose power and told me I had to do the work live. I knew that a loss of power wouldn't result in ANY life safety conditions and I knew that running power through the bus in the state it was in would present significant life safety hazards so I threw the main off, locked out the cabinet and called the utility company for immediate emergency disconnect.
Had it repaired in an hour and had the power restored by the utility shortly after.
There are very few circumstances where circuits, equipment or live switchgear need to be worked on live. Any properly licensed professional should know this and should be properly trained and provided ALL the proper PPE for those few circumstances where hot work may be necessary.
Just my two cents.
BreeStephany
Oregon
This. Operational inconveniences do not necessitate risk of life.
I started my work in the trade working beside a guy who had previously had to spend MONTHS in a burn unit after discovering that the person before him hacked together an incorrectly sized bucket into a MCC on a 20~25kA bus and he got thrown through a wall from the bucket ejecting from an arc flash.
I think it's important that people understand that an arc flash can reach 30k F and is LETHAL and forceful!
