As some of you might know from another thread of mine, I have a couple broken bolts to deal with in my cylinder head, still installed in my Roadmaster. The exhaust manifold bolts broke flush or just below the surface of the head. The manifold has been removed.
The space is tight, with a steering shaft in the way. I was going to try to weld a nut and washer onto the bolt to remove it, but I loaned my welder out some time ago and my buddy still needs it for a project. So, my other buddy suggested an EZ-Out or left-hand drill bit. It might be worth a shot.
I will need a very compact right-angle drill if I am to have any hope of drilling into the bolt with any degree of straightness. Can anyone suggest a very compact model?
Than you.
Than you.
