klhitman
Flat Blade Screwdriver. those screws should have been eliminated years ago.
yes yes yes and good like using a drill on one!!!!!
So you have to pay their techs to remove them! Genius!phillips screws and impact drivers,rebuilt a yamaha virago other day,the side covers and the cases were held together with philips screws,really if the japanese are so much smarter then why do they still use phillips screws to hold a motor together
I'll agree with you on the chainsaw as well. Honestly, it seems it doesn't matter if the saw is in PERFECT running condition, or if you drain it, or put Sta-Bil in it, it seems no matter what I do, it will absolutely refuse to start in the spring after storing it for the winter.I'll meed you a string trimmer and raise you a chainsaw. I have been cutting down a bunch of pine trees lately to stop the spread of "pine bark bore beetles." Pine gets that wonderful pitch on the blade which makes it more likely to cut your flesh than anything on the tree. If the gas isn't mixed perfectly, then they can be temteramental in the winter. Really, I have a backhoe at my disposal, not sure why I still fight with a chainsaw, but I do.
They weren't phillips. Get a good set of JIS drivers, you'll have much more luck.
I so cannot wait to get my set of Vessel JIS drivers...They weren't phillips. Get a good set of JIS drivers, you'll have much more luck.
What is the most aggravating, hateful tool you have ever used? For me, undoubtedly, it is a handheld grease gun. I get pissed off every time I pick one up, because I know it's going to make me furious before I put it down, anyway. It can pump great, but the minute you climb into a piece of machinery or under a car, it will make 2 pumps and quit. Reloading and priming one is another adventure unto itself. I have used all the major brands for over 45 years, and have yet to find one that won't end up ruining my day.
Rant over. Your most hated tool?
trouble lights. It doesnt matter what fancy mechanism they have to hang them or hold them, they always swing around and end up pointing right in my eyes instead of what Im working on. Im convinced thats why they are called trouble lights, because they cause me nothing but trouble
C-man Quick Wrenches. The Combination wrenches with a notch in the open end.
They're so ridiculous to use and it actually slows me down. I just want to toss them in the trash everytime I use them but they're the only wrenches I have at home.
I still have them, but I definately won't be using them. More of a "gimmick" for the homeowner or would-be mechanic.
think how many keys you have and how many you have no clue what they go to...
Any front tine garden tiller
For me it's almost always a Goodyear that needs the Cheetah. Damn things are just too narrow for their sized rims. I have to somehow wedge the tire mounting machine's air chuck lever in the on position, so it's constantly blowing through the valve stem, get the tire set up just right, and then blast it with the Cheetah and hope it seats the beads. Plus it's louder than hell in our small, eight-by-twelve concrete walled tire room.3. Cheetah bead seater - The fact you're using it means that you're working with a stupid pain in the *** tire that won't seat. Screwed before you even use the tool.
