Moto race shop remodel
Sheriff245
We purchased this garage in the spring of 2011. It is 22x26 with a basement and attached house. Ground level has a 9' ceiling, and basement is just under 7'. Before moving in, we had a local contractor install a polyurea floor coating for the ground level. Things were set up on the cheap, but functional. In the last 2 years, I've used the garage as is, building some pretty elaborate projects in it, and it gave me a pretty good idea of what I want and need.
One of my projects was a Chevy Express build. It required some creativity to cram everything I needed in a relatively small package, and I plan on using my experience in that department to get the most out of my garage.
Here is how it sat last summer before I started the project:
Ground level was functional, but I wanted everything to have a place out of sight, and some clean place to relax after a long day's work.
Basement is primarily used as a storage area, but scattering everything on the floor is simply a waste of space.
The lady wanted the house basement finished, so I decided to tackle both projects at the same time, mainly because I don't like doing construction work and wanted to get everything over with. The basement is quite uninteresting: family room, 2 bedrooms, bathroom, laundry room. Now on to the interesting stuff.
I have had my plan thought out in my head for a while, and this fall I stumbled upon a set of kitchen cabinets in good shape for $300. After some haggling I brought it home for $175. I don't have pictures of it right now, but you'll see it later come refurbish time. With the cabinets on hand I laid them out to paper to try and fit them in the space I had. Last week I came on here and saw another member made a model using Google Sketchup. So I did the same.
Ground level will be used as a dirt bike maintenance shop and man lounge, walls and ceiling will be drywalled:
Partition wall will be erected in front of the stair well, and the L shaped cabinetry will go in that corner with a stainless steel countertop. On the left end, I'll put a 72" shop pantry I found on sale for $99 at Canadian Tire. In the right part, a Mastercraft Maximum 47" tool chest (lower only) will be incorporated into the cabinets. I got it on sale for $499 on Thanksgiving weekend. On its right, a solvent cleaner will sit under the counter and will be accessible via a flip up panel held in place with a hydraulic piston. When not in use, the panel will be flipped down, giving me almost 3 extra feet of counter top surface. Under the cleaner, I will place my glass-door beer cooler.
To the left of the house door, a sink will be placed right next to a flat screen TV in the corner above the lawn mower. The garden hose reel will be moved closer to the garage door, and an air hose reel will be added above the sink, and connected to the air compressor, which is going downstairs. On the opposite side will be the bike and race gas storage, and lounge area.
Nothing too elaborate here, just some place to sit and enjoy a cold one, watching Supercross on TV or listening to some good music with friends. Or just a place for the lady to browse through the Face Book while I work on her bike.
As I want to keep the ground level clean for the most part, the more dirty work (and noisy air compressor) is going downstairs. Half of the space downstairs will host shelving to store stuff, parts, and such, while the other half will host my current work bench with the more noisy/dirty tools, and some new ones I want to own some day.
My current toolbox, a cheapo Craftsman topper, will go under the bench to make room for some tooling.
As it sits right now, only the studs for the staircase wall were added since the pictures were taken. We are currently working on the house basement, but should be switching on the other side soon. At least I know everything will fit with a bit of room to spare now that I have drafted it. I will post pictures and details of the project as it evolves.
ripper70
Oregon Coast
That is a pretty sweet set up! The fun part is watching it take shape then using it. Keep us posted with pics. Some diamond plate snaplock tiles might look pretty nice on the floor around your bench.
Gentle_Ben
Manitoba, Canada
Great sketches!
I spent so many hours doing different sketches of different layouts for our garage. I quite enjoyed learning to do that.
Aquaticbob
Seattle
Really liking that work bench layout. I like how the parts cleaner is incorporated on the end there, might borrow that idea for a bench that I am planning out currently. The 2 level idea is really good too, noisy, dirtier stuff in the basement will be nice to keep out of the hangout/work area. Is the air compressor going to feed directly up? Also, maybe incorporating a little cargo lift could be nice for the heavier items you might be toting up and down the stairs.
Just curious, but what software did you use to design all that up?
Sheriff245
Feel free to use my idea, and share your progress so others can use yours!
I need to drill a hole through the slab for the sink, I will just make it a bit larger and pass a hard line for the compressor through there at the same time.
The heaviest thing I will need to move up and down the stairs is the snow blower, which is pretty easy to move up and down the stairs with a buddy.
I used Google Sketchup. It is a free software with a large database of user-created contents, very easy to use.
Sheriff245
Little update: the toolbox came in yesterday.
The blue is the actual color of the handles, not a protective film.
e-tek
Saskatoon, SK
Holy **** - now I need a "Google-garage" - lol!nWhat a great tool. The MC box is already a reality, so the rest should come soon! I suggest to everyone the use of an outside shed for bikes and mowers, but if you can hang or tuck them away that works too.
I may have to use some of these ideas for my attached garage makeover this spring!
Sheriff245
The shed will be coming some day that's for sure.
Yesterday while the baby was sleeping I worked a bit in the garage.
Mounted up some plywood for the upper cabinets (not done yet)
Electrical work is coming along nicely. My brother is coming back tomorrow to finish the job.
Nothing new here, but I just wanted to post a picture of my heating unit. It works really well, especially since we moved the thermostat away from a window (see picture 2 of this post)
For now I'll be rushing to finish the basement and get it ready for drywall. I'll have both the basement and garage done at the same time. I still have a few things to get done in the garage too, like cables for the TV and stuff. I expect to be done in the next few weeks.
Sheriff245
FredBull
Very nice sketch up! I especially like the use of the McGrath bike in it :thumbup:
I would love to have a basement under my garage/shop. It would open SO many more possiblities for storage and, as you are doing, putting the compressor out of ears way.
I look forward to updates. Good luck!
Sheriff245
Here's a little update. The drywall/mud guys are coming next week to finish up the basement, and they'll be doing the garage at the same time, so I'm rushing to get things done right now.
These last few days I've been busy getting the walls ready, routing AV wiring, and fixing the vapour barriers.
Here's another shot before the final clean up. As you can see I still have lots of work to do.
Oh, and the main accessory to this garage showed up in the mail yesterday...
gasgas17
Nova Scotia, Canada
Nice to see another dirt bike guy around here. You have a nice space to work with. Mine is pretty functional but a bit on the small side.
UncleDirty
Riverside Ca
Nice project Sheriff. Looks like you are going to have a sano moto shop.
I see you are a fellow two stroke racer too, right on..:thumbup:
I need to get one of those candles. The website said they are made with real Blendzall.
fredtech
Manvel, Texas
I really like what you're doing with the place.
I had a good laugh at the candle, I may even order a few :thumbup:
My garage is mainly motocross also. Subscribed.
De quelle region es-tu? J'ai grandi sur la rive-sud de Montreal :canada:
wrenchMONKEY_
You are right, I didn't give any info on it. It's a Stelpro Dragon, 5000W ceiling fan heater. It has a heating element wrapped around a fan that recirculates the warm air near the ceiling through the room. It's expensive, but it's well worth the price.
http://us.stelpro.com/web_items/web_att_details.asp?attid=V¶µ¤†/tqmw
I have the same heater. Love it and does a great job since I cant run NG to my garage. Quick question, I have the built in thermostat in minem but I am curious, did yours come OEM with a wall mounted one or did you just re-wire it form the unit to run off a wall thermostat? I just keep it set via the thermostat and then flip it on and off at the breaker as needed. I'd love a thermostat instead to turn it on when I need to. I don't keep it on all the time, just when I am working in the garage. It heats up my 26x30 to in about an hour.
Looking at the StelPro website, which model of thermostat did you install?
I had two at one time, a Step Pro, RUH 5000W 240V, but while running both at the same time was warm an toasty, to much $ to run.
Sheriff245
I like your place. I tend to be excessive in everything I do, but I have to admit a place like yours is more than enough for the kind of work we do.
Back in 2011 I rode a 250F and was getting bored with the sport. Then I took out my old 125 and started having fun again. I sold both bikes and got a brand new 2012 YZ125. I built the engine myself to make it a 144 stroker. Pulls out of corners like a 250.
Later on I found a good deal on a used YZ250 engine. Bought a used 2010 YZ250F and shoved the engine in it. Made for an amazing bike.
Je suis de la Beauce.
The unit I have was made to be used with a wall-mounted thermostat. I'm not sure which one it is, either the 1G65 or 1G66. I'm not sure, but I think you could use a wall-mounted thermostat and just set the on-board thermostat all the way up at all times?
gasgas17
Nova Scotia, Canada
The yellow GasGas 125 is also bored to a 144. In fact it uses the same piston as the Yamaha 144. That bike did double duty for 5 years racing both mx and hair scrambles. I currently have a GasGas EC250 and plan to make a change this year to a Sherco 300 2t. I would love to have some more room, but I use the big garage for my work. Nice YZ 250 btw.
Sheriff245
OK...have to ask. What difference does the 250 in the new frame have? Very curious! lOOKS SWEET!
I haven't ridden a regular 250 in a long time, so it's hard to compare at the moment, but I plan on doing a shoot out come spring time. What I can tell you is I hated it the first time I rode it. It seems like engine conversions require some heavy suspension tuning. Once I got that dialed in, the bike is excellent in every way. Handling and stability are just as good as the 250F, rear wheel traction is impressive for a two stroke.
kippieland
Western Washington
Can't wait to see your shoot out. Just curious....I have both a YZ450 and 06 250 2str. I have to set the suspension very different compared to each other. The bike looks sweet.
Sheriff245
After 3 days of cleaning and re-organizing, I finally got to get the place empty. The drywall is coming in tomorrow.
I left a little surprise for the next owner to remove the drywall
A view of the garage basement. If you're wondering how much stuff I own, this is about half of it stacked in there. It did not fit in the picture.
sbhockey
Chattanooga, TN
Lovin the shop. Actually did the same thing under the OSB in my old garage withe a shroud graphic. Rode my last MX bike about 10 years ago when I got started road racing. Picked up a basket case YZ125 a couple weeks ago, going to get back on a dirty bike again. Never spent any time on the 4 stroke's no plans to, because you cant brapp a 4 stroke.
Sheriff245
I also plan on doing up a human silhouette with white electrical tape with splashes of reddish brown paint on the basement floor before putting up the wood. Should be pretty funny.
What year YZ did you get? they're great bikes. Very reliable and fast.
Drywall is going on as we speak. They've been working for 2 hours and almost done with the garage. Next up is the basement. Mudding should start some time today.
Sheriff245
I never felt like painting walls like I do now. Should be priming this weekend if all goes well.
sbhockey
Chattanooga, TN
Bike's an 03'. Pretty old, but 2 stroke technology didn't really progress much past 05 when the 4 strokes really took over. For a $300 basket case I really couldn't say no. By the time I get done picking up missing parts and building a 144 cheater I should only be in for about $1,000. Cheap ticket to get back into riding moto.
kippieland
Western Washington
Steel framed YZ's are awesome. The change to the alum. frame did the 125 a great job....still the fast 125 around. The 250 is sweet as well.:thumbup:
