Motorcycle road tool kit
Jure
Croatia
Just curious what other people carry when riding. I made a new tool kit after realizing that I won't be removing the wheel on the bike that has no center stand. Majority of tools in original suzuki's tool kit were tools needed to take the wheel off.
Not long ago I had to take the tank off in the middle of nowhere,and had no tools to do it. It was a nightmare,fuel line fell off the carbs and fuel was leaking all over the hot engine. Worst of all i knew that vaccum petcock on that bike has to be rebuilt,its leaking with the engine off. So I had to pull off the line from the tank and stick a piece of wood to stop the leaking till waiting for a tow.
Idea was to pack small,small enough to fit under the seat in the "tool kit pocket".
20250109_144522.jpg20250109_144615.jpg20250109_144703.jpg20250109_144736.jpg20250109_145110.jpg20250109_145258.jpg20250109_153356.jpg
Numerator2142
The right answer depends on your bike and how far out of they way you're going.
Smart money says pay attention to the stuff you need to do maintenance and that'll help you pick out the right sizes to bring for your bike.
Dumb money says all you need to carry is a credit card.
I carry some smaller needle nose locking plies because they can help jerry rig workable levers. I wouldn't totally discard wheel removal tools if they're less common because you might get somewhere with some stuff but not everything. Like my bike needs a 19 mm Allen and a 20-something (1 1/4" in metric) hex to remove the wheel. I wouldn't assume a random garage (not owned by a gj member) would have those.
Rusted Nut
PNW
I do at least one long ride a year, many times fairly remote roads. I carry a knife, pliers, couple torx bits, baling wire, duct tape, zip ties, and tire patch/plug/pump; not much. Credit card for tow truck and motel. Not much you can fix on the road.
cablebandit
qgxd5ookrv735h0lrb31vwck6ru4.jpg I can pretty much take my CRF completely apart with this and a couple combo tire levers. The Concours has it's own set.
My thoughts are work on the bike in the garage with the tools you'll have on the trail. That way you know what you need and what's unnecessary.
If you really want to go down the rabbit hole check out the toolkit thread on ADVRider. Lots of good ideas over there, but there comes a point when importing lightened titanium wrenches from Japan to save 30 grams on your 600 pound "adventure" bike seems a little silly. BTW, that's usually posted by some dude who's money would be better spent chugging Ozempic. ;)
bobg03
conway sc
Cruz Tools makes a set for many different bikes and levels of repair, comes packaged in a small bag. I had two for my three Harleys, One that had a large variety for my touring bike hard bags and one with less things that fit in the handlebar bag on my two Superglides. Never met anything I couldn't tackle w/either kit.
MovingAlong
Know your bike, know what the "typical" problems are. When I rode, a volt meter was my primary tool... a Leatherman provided enough backup for other tasks when needed. But electrical issues were 95% of my issues on an older (1980's) bike.
Other than that: cell phone, AAA, Visa.
There is a cost to dragging around a full toolkit. And even with the tools you'll often lack the replacement parts: spark plugs, spark boxes, carb cleaner, fuel pump, hydraulic fluid, clutch cable, brake pads, battery, switches, etc..
For me - traveled light and accepted that breakdowns were going to take some time to resolve.
bwringer
Indianapolis
FWIW, here's an article I wrote on this very topic. This is not a boring-*** list of tools and loving close-ups, it's more a framework for deciding what to pack for any given motorcycle, rider, and ride:
My kit is perhaps more comprehensive than most, for a few reasons.
1) I move my kit between three bikes. They're all Japanese brands with very different purposes. Most things overlap, but there are a few added odds and ends needed, especially for dual-sport riding. I have a vintage Suzuki, a dual-sport Kawasaki with tubed tires, and a modern Yamaha sport-tourer. Maybe I should put together three kits, but it would cost a fair bit and would save very little space or weight, and have little effect on convenience.
2) I ride solo most often, but I often ride with people on European brands. A few added things like 13mm sockets and Torx bits help cover these machines without adding much weight. I rarely, if ever, ride with people on Harleys, so I don't carry inch tools. (BMWs generally come with decent tool kits, but torx bits with a ratchet can save a lot of time over using the L-keys in the kit.)
3) When a bike falls silent, all eyes seem to swivel my way... I'm almost always the "fixer" in any given group of riders, so I have a more comprehensive tool set than most because I most often end up using it on other people's motorcycles.
I would disagree with the notion that wheel removal tools aren't needed, but I can see the point as well; on a bike with tubeless tires, situations where you'd need to remove the wheel are fairly rare. Obviously, wheel removal tools are a must on a bike with tube tires.
I think the absolute minimum for bikes with tubeless tires would include a tire puncture plug kit and a means to get air back into the tire. Tire punctures are by far the most common show-stopper on the road. Sticky string plugs are simple, cheap, and reliable, and I'm partial to Nealey kits; they're compact and installed a little differently, and don't require glue, and in my opinion work a little better than the usual stickies.
As to air replacement, there are now some excellent self-contained battery-powered pumps. However, they're limited by the built-in battery's capacity and take a while to recharge, so at the moment I still prefer electric pumps powered via the bike's battery. There are cheap ones in any Wally World, but the MotoPumps Air Shot 2.1 is a distinct cut above.
Other than that, it depends on what you're comfortable tackling, what the odds are, and what scares you the most.
Tools to remove the bodywork and tank. and adjust the controls are a minimum, I think. If a bike gets dropped, it's quite often rideable if you can tweak the controls back into place, and of course any number of simple issues can be handled if you can get under the bodywork. (For example, I've replaced several dead/dying batteries in auto parts store parking lots.)
The stock tool kit usually contains a spark plug wrench (sometimes this is the only thing that will work on certain bikes) and super-janky wheel removal tools. Whether to tote these or replace them is a personal decision. It's very rare to have to touch the spark plugs on modern fuel-injected bikes between scheduled replacements.
A decent simple, compact multi-tool serves several purposes (obviously); many are over-burdened with useless stuff, so keep it as light and simple as you can, but invest in name brand quality, like Leatherman, SOG, Gerber, etc.
I also carry a small digital multimeter, and a few bits of wire, and some Posi-Lock and Pos-Tap connectors. This is mainly to address known weaknesses in the vintage side of my riding, but a small multimeter really can come in handy for things like assessing batteries, lighting, relays, charging systems, etc. on modern bikes as well.
It's also nice for at least one rider in a group to carry a jump pack or compact jumper cables; this can certainly save the day. And if you're riding in a group, you shouldn't need more than one tire repair kit or air pump.
M.Brane
1 hr N/W of LA LA Land
Other than the basic kit that came with the VFR I keep some small needle-nose vise grips, magnet on a stick, zip ties, duct tape, electrical tape, some primary wire, wire nuts, and a cheap multimeter.
I've had a few R/R meltdowns on VFRs before (I've owned 4 IYKYK), but not since I upgraded to Shindengen SH847s, and bypassed the stock charging system wiring.
J
Jure
Croatia
I think the absolute minimum for bikes with tubeless tires would include a tire puncture plug kit and a means to get air back into the tire. Tire punctures are by far the most common show-stopped on the road.
yea,i had tire repair kit on my mind...this is what i filled in my tool kit:
Double open end :
12-14 mm
10-13 mm
17-19 mm
1/4 drive:
Long extension
Short extension
3" breaker bar
Sliding t handle
1/4 to 3/8 adapter
Nut driver with square in the handle
1/4 bit holder
2, 2.5, 3, 4, 5, 6 and 8 mm allen bit sockets
6,7,8,10,12,13 and 14 mm sockets
3/8 drive:
16mm spark plug socket - just in case of hydro lock.
Extra things:
Two sided suzuki tool kit screwdriver (90's) jis type.
Wiha screwdriver with bit holder filled with bits
Insulation tape
Piece of wire
9 extra fuses 10-15-30 amp (3 of each)
Knipex cobra
Knipex small cutters
L shaped short allens (2,3,4,5 and 6mm)
Piece of rag
10x zip ties
Piece of fuel line
That's what i was able to pack in a poach little larger than a cigarette pack. Main goal was to be able to deal with tank removing and fixing the simple things. I dont see myself splitting the case and changing the dog ears on the road lol. I think i got the basic things covered.
Trapps
The Detroit Zoo
I second the ADVrider toolkit thread. Close to 10,000 posts. You'll have to weed through a lot of bs (see Ozempic chugger reference above), but there is great content there.
This is the stock kit for my bike:
This is what I ended up packing:
I was not overly concerned with weight or space. The oddball is the 55mm socket for the rear wheel. I'll add some Gorilla tape next time but that's it.
Leaflessshadetree
Don't ask.
I carry a few basic tools, and a small tire plug kit and compressor on most my bikes. I try to use the set occasionally when I'm at home. That way I know for sure that I have the sizes I need and tools that work/fit. Most stuff I've fixed on the road is simple stuff that has come loose (mirrors, shifter or accessories).
i84x
Earth
Metal tie wraps can come in handy too, stronger and don't melt if they're near heat.
