Mounts for a blade on a 1981, CJ
ShuhornGarage
My neighbour has a '81 CJ & wants to mount a front mount blade on it & we're wondering if anyone has done so & what was used for material & design for mounting brackets
We "think" we have the front bracket figured out (done & installed) but are having some challenges figuring out the rear mount & the connecting material
Any ideas, measurements &/or photos will be greatly appreaicated
Thanks
Norm
ShuhornGarage
Thanks
Norm
imagineer
I put a plow on a '97 TJ and it was a bracket the bolted to the front frame rails, using the steering box bolts on the left side.
The bracket was 1/4" steel with a 2" x 1/4" wall square tube spanning between. There were "U" brackets welded to the front side of the tube for receiving the plow yoke.
I had to make my own brackets (that bolted to the front frame after removing the bumper) to hold the hydraulic unit.
K'ledgeBldr
Johns Creek, GA
ShuhornGarage
Thanks for your reply, much appreciated
ShuhornGarage
Maybe this will help-
Thanks, I will forward the info, mcuch appreciated
ShuhornGarage
We got it figured out & done, appears to work well, likely over built it but better than having it fall off :) :), thanks for the suggestions
