Eriehunter
- Joined
- Mar 14, 2014
- Messages
- 189
Here's something that you may find useful.
With the changing temps and weather the mice that are normally outside will want to find a place inside that is warm and dry. No so much a problem in the summer as I don't keep food inside my pole barn, but with warmer temps than outside they will move inside as the temps drop.
After talking to the rodent control guy a food manufacturing plant awhile back he thought it best to kill them outside the building first. Then if the do get inside the building have the traps inside as well.
So I have had traps inside, just like everybody else but outside is kinda different. He recommended bait stations outside and multi catch inside.
Bait stations
I got two of these on for either side of the overhead door. About $8 each ordered them online at Home Depot and shipped to the local store for free.
You will need bait
four packets of Decon in a box for $5 at the local Dollar General
Open the bait station and put bait inside
This type of bait station calls for a solid block that hangs on the spring inside the station. They didn't have that type at the store so this will do, and actually may be better IMO because they may carry some back to their nest and kill off the little ones. But if you have pets or children the loose bait could be shaken out and consumed. Beware.
Placing of the station
By the overhead door on each side as this seems to where they want to come in and it doesn't get too wet and flood there. So the bait inside stays dry. Today is the second time I have had to refill this bait station, so they are taking the bait. The leaf by the door is where they get inside, I address this later.
Multi catch
I got three of these. They were about $4 IIRC and they were in stock at the local Home Depot
You place these inside the building around perimeter walls and such "scurry lines" I put a little peanut butter inside to draw them in.
Ont thing that I didn't show is that I also put peanut butter farther back in the trap, like a trail, to encourage them to go all the way in. these will catch more than one mouse.
Placement of multicatch
close to entry points and also one along back wall in the "scurry line"
Notice the daylight, this is where they chewed their way in through the door gasket and weatherstrip. This is the location of the leaf outside.
The picture is a approximately where the multicatch is located but I rearranged the pipe pile so it was better suited to that location.
I also fabbed up a metal plate where the security breach was.
This is the metal plate and will get screwed to the wood by the overhead door, it will lay horizontal lengthwise, between the weatherstripping and the door.
I also had two snap traps that I located elsewhere in the building, one close to the air compressor and one along another "scurry line"
All summer I used the Bait stations and multi catch, haven't seen one in the building yet. I knew about the breach in security and just got around to fixing it today. Hopefully those little infidels will be gone !
Bait stations
You will need bait
Multi catch
