Moving a breaker.
Herb
CT
I'm getting ready to install a generator interlock on my breaker panel. The style panel I have requires a blank space under the generator breaker for the interlock to operate correctly. The nearest location for me to move the breaker that is in that spot is further than the conducter will reach. My question is- can I simply move the breaker to the needed location and make an extension out of the same gauge wire and connect it with a wire nut?
madosta
Omg... although your avatar is very intriguing, when I view posts made by you at work, I wonder if anyone happens to notice that as well...
I can't read your post right now as it's scrolled up hiding your avatar.
Yea yea yea. I should prob be working, but my job is ******. I'll look again later at home... ;)
pattenp
Virginia - USA
Yes you can splice on an extension using a wire nut. Can you jockey all the breakers so not to have a splice?
H
Herb
CT
One or two I could, but there are others that would not be easy to move. I just wanted to be assured that an extension would not violate some portion of the NEC.
allinon72
Indianapolis
I was under the impression that these types of splices inside the box were frowned upon. That said, I have several in my house (old)
Rookie2
Western Pa.
what was i thinking ? she would probably kill me.
its a don't ask don't tell on the wire nut. i believe to be legal you would have to make the connection in a box outside the panel.
KenC
oklahoma
Lots of those are done, and legally! Just be neat about it. Tight bends, etc. I like to use some small wire ties to keep things lined up.
pattenp
Virginia - USA
It is approved to have splices in the overcurrent device enclosure. 2011 NEC 312.8.
madosta
Yea what pattenp said... but more importantly... your avatar.
Who is she?
And guys let me tell you something about hot women. No matter how hot they are some guy, somewhere is sick of putting up with her!
Norcal
The "code" not allowing splices in a panel gutter space can be found in the Urban Legend Code. :lol:
H
Herb
CT
I tried a brief search, but I couldn't find any more images of her. Maybe someone that is more computer savvy could?;)
Vince1955
Pennsylvania
A quick and easy solution would be what you're suggesting, but in the long run, disconnect the black, white and ground - pull the wires out of the breaker box and use an external junction box. Make your splice in the ext. junction box then run a new section of Romex back into the breaker box and reconnect the three wires accordingly. This will remove any potential "HOT" wire from coming loose, shorting itself, or electrifying the metal breaker box. Just to be on the safe side.
BFBOB
Yup. I thought that until a real sparky set me straight. Splice to feed two wires into a breaker ok, two wires into the breaker not ok (unless the breaker is specifically rated for it).
Are we confused yet?
Alchymist
Central PA
"Electrifying" the metal breaker box? Not likely.
Norcal
Yup. I thought that until a real sparky set me straight. Splice to feed two wires into a breaker ok,two wires into the breaker not ok (unless the breaker is specifically rated for it).
A splice in the gutter in a panel & two wires under a lug are two different beasts, the former is permitted by code, the latter is a listing violation, which in turn is a code violation because the NEC requires listing & labeling instructions be followed.
The only breakers I am sure that 2 wires under a lug is allowed is, SQ D QO 15 & 20A models. HOM may be allowed also.
