zmotorsports
Absolutely amazing workmanship Robert. Thank you for sharing.
Looking Fantastic Robert! I painted a 900 Kawasaki that color many moons ago bike was pretty much new. Prob still have a splash of it left. Jon Kosmoski told me years ago if the paint will still mix you can use it! Still have tons of HOK paint left. '66 F100 clone of one my dad bought new will be getting HOK Red pretty close to the original J code red. Hope it works as it's 35+ yrs old.Last bit of progress, we got the hinges painted so hopefully we can get the tailgate installed this weekend...
installing more shiny stuff....
We had not pre-drill the holes for the partial spear on the doors when we installed new door skins, so here we mask off the bottom of the door and drill SLOWLY to prevent heat buildup.
Then the fresh holes are touched up with two coats of epoxy primer. Once dry the spears are added..
And our dash clock showed up so we can get that hole filled as well
For the 240 volts you measure from one hot leg to the other. Just like your clothes dryer and oven use. Unless your brake is a 120v machine…These are the cracks that I was talking about, both rows have them.
I do have a crack center and to the left and the right on both front and back coil, six cracks total.
After seeing yours makes me wonder if I should fill the voids with epoxy like JB Weld and look into the getting a box like you.
Any ideas on getting the actual voltages coming in to my shop. I have measured 120 volts a bunch of times but not 240 volts. Could I measure each 120 line and add them up to get my 240 volts actuals?
Thank you!
I checked the voltage, and I turns out I'm getting 244 volts, my brake is rated at 240 volts "per the data plate on the front of the brake"
The handle rests against the steering link in the middle. Where this is going is primarily flat, no hills, so brakes have not been discussed..What does the handle rest against when it is "attack" mode?
Any reason to add a small brake lever on one side to apply pressure to the face of a rear tire? ( I grew up on a hill)
I'm guessing air ride is another missed opportunity.The handle rests against the steering link in the middle. Where this is going is primarily flat, no hills, so brakes have not been discussed..
So I’m like “What did I miss?” Had to scroll back and look to see. Sometimes the treasure is hiding in plain sight!I love that old Ditzler cabinet.
If he was an actual friend, he would have called you first.Here's the pair when I picked them up back in 2019. A friend put them on marketplace and I was first to call.
Pull rods and clips - why painting, not sending for zinc plating?
