Multiple 220V outlets on 50A breaker for 2 Tesla's.
GWheat
Can I run 2 plugs 220V in the garage for Tesla's off of one 50A breaker?
jeepxj
no. not to code or common sense if you're trying to charge 2 at once.
you can however team up multiple gen 2 HPWC's off a single breaker. the new gen 3 HPWC's require their own home runs but can team together to reduce load.
510ebl
Southern New Jersey
So the recepticles are against code, but hard wired is OK?
And am I understanding correctly that the gen 3 HPWC’s communicate with one another to balance demand?
jeepxj
they're ok for code you just need to have them on a GFCI. if you hard wire most of the good brands have a built in GFCI meaning you can use a "dumb" breaker on the circuit. grizz, tesla, clippercreek,chargepoint etc.
the gen 2 HPWC's used a wire to communicate between the units. the Gen 3s use wifi to figure it out. either generation is capable of load share.
