Multiple switches for soffit lights?
Moosefire
Detroit
So, with my new garage nearing it's final stages of assembly, I'm looking to get some details in it before the interior gets finished. One if the things I want is soffit lights / eave lights. I see there's a programmable light switch, whi h makes things real nice as I don't have to mess with it all the time or forget to turn it off. The only problem I've found is I can't find a programmable switch that is also dimmable. I want the option to dim the lights if they're too bright.
My question, would be (and I don't see why it wouldn't work...) can I wire power thru the programmable switch, then go from that switch to a dimmer switch, then out to the soffit lights? Seems ridiculous to have 2 switches to do this, but I've searched for about 2 hours and cannot Fina a programmable dimmer switch.
Does this seem like it would work? Am I missing something?
Do you know of a switch that meets my needs?
Any help is appreciated!
Paul_The_Builder
Dallas, TX
There are dozens of smart dimmer switches that can be controlled through a smart home software or hub, and be put on a schedule, etc. A lot of them can be set up as 3-way and 4-way switches also.
I have a bunch of GE Zwave dimmer switches that I quite like. I believe they're now sold under the brand name "Enbrighten". Lots of other choices too depending on what type of connection you want (zwave, zigbee, wifi, etc)
Moosefire
Detroit
Thanks guys! I saw similar switches come up but assumed they were just dimmers. Just to double check, those can be programmed thru the app, right? I don't have alexa or any other smart home anything to pair it to, nor do I want one.
kbuhagiar
Escondido, CA
Leviton has its own app.
TRWham
East Cobb County, Georgia
Caseta is Lutron, not Leviton. I have a couple of Caseta switches, one of which has become a little too independent of late and does not always follow the programming.
