bcradio
For me it would be a complete set of impact tools, impact sockets (of all kinds), and powered ratchets.
Makes EVERYTHING easier.
Disagree. The longer handle is where the better pliers shine. For me, if I need to reach something I can't get without my hand or smaller pliers, then I need the tool to absolutely work, no exceptions. The cheap ones will bend, or the jaws will twist and lose grip on the item.
What happened to a hammer, wd-40, and duct tape?
I have found I typically buy tools based on need, not desire. If I have a project coming up (I am a DIY shade tree mechanic type) I try to plan ahead for tool requirements. What I have found is tools you use a lot like hammers, screwdrivers, ratchets, bench vise....etc, you should invest time into research and spend money where needed. I buy cheap stuff when I don't plan on using it often, but sometimes later find I use it more then I thought I would and it just ends up ******* me off in the long run. Good example is a harbor freight heat gun. It works 100% of the time, but the cord on that thing is such a royal pain I almost despise using it.
One of those contraptions that lifts the car so they can be walked under.. I used them when working in dealerships. It was nice when I didn't have to pretend to be a worm when working under a car.
