My 1000 LB bench
therealjakeg
Got the bench done. Works awesome and I can move it with a finger. Enjoy.
T
therealjakeg
3/4” top with hydraulic jacks on both sides and wheels to let it down. Edge of the table was cut on a water jet to get a square edge and radius the corners slightly. 4’x8’ weighing in at just over 1000 lbs with the frame. Thanks for looking.
Jake
98227b1dca1a479c90dde14f2fb4bd2b.jpgb52206251239743efbfa1e2da8695dff.jpgc33591954a22822dbe16ac76182cfda6.jpg85ccee4ad0b8acece59825ccede12c12.jpgc9742c1d02ce427b5507bf2c52607786.jpg31425281bf336a1b96d9bff242da96de.jpg
kunkernator
US of A
I love the idea for jacking the table up. What brand casters did you use? I priced some out with Caster Concepts a while back, but they are way too expensive, so i decided not to do the project....
Bears Fan
Indiana
Awesome table! You had me with the thread title, I had to check it out :thumbup: I was impressed with those magnets holding that top up :beer:
tool_scrounge
Southern California
Jake
Nice table. I might recommend being very careful on what you roll the wheels over. Flat concrete is probably fine. But if you hit any bumps the threaded rod to caster interface may break.
What you have constructed is very similar in size and weight to a vibration isolation table. In that world the tables are not moved often, but on initial installation they may be moved from the loading dock thru the office building to the final destination. One of my suppliers had a similar (if not more conservative) design and they had no less than three redesigns to deal with breaking the casters off. There is nothing less fun than having a customer looking over shoulder as you hacksaw off a bent/broken caster assy on their $150K tool.
I found the most robust solution was to mount the caster fixed and raise/lower the feet. The reason is the vertical adjust mechanism (screw feet) only see static loads. Unlike the casters which see static and dynamic loads as you move it. The example swivel foot is rated for 7400 lbs. But deploying it is not as fast as your two hydraulic jack solution.
Wesley B
No where
Looks great, a lot simpler than most of these I've seen. What are the specs of the tubing you used for the frame?
JMLangford
Upstate SC
Nice looking table!....
I too was thinking like tool_scrounge, that the rods on the casters looked a bit anemic for such a robust table....
