Hey 75, I don’t think I’ll do a specific build thread because this will be a very slow build, seeing as the house and property are still going to be my priorities. But I will put it in my reno thread. As I said, I’m going to bug you, so the question is how would you drop the front end? Spindles? Aftermarket control arms? Modified control arms? All the above? I’m pretty sure the truck will be bagged all the way around. I figure once I understand how far the front drops, I can design the rear.
So I will answer you question with a couple questions of my own first. How low do you want it in the end (biggest question of them all!) If bagged then here is what I would say if money was no object. First get a really good dropped spindle (prefer Beltech), the lower the better because it will maintain the factory geometry. Then a good set of tubular or aftermarket A-arms (Porterbuilt makes amazing stuff!). I would say modify your stock units, but I don't know your level of fab skills, so go with someone who knows what they are doing because everything in suspension means possible injury or death if you ****** up a weld. Tons of stress on all these parts...
As far as bags go, get the biggest you can fit in the space available. Some folks will say use a 2600 bag, and they have had good results, maybe they have, but then ask them about the ride quality... I used 3800 series from airbaggit.com and they have been great. Yes they were not the easiest to fit in there, but the effort was worth it. There are a lot of new bags on the market since I bought these, and I may switch out at some point, but they will have to have the load carrying capabilities and the ride quality better than the bags I have today for me to switch.
So in the end I really suggest that you look at Porterbuilt or GSI Fabrication. They have everything from 1/2 ton complete replacement suspensions to 1 ton stuff too. The reason I say this is that they are complete systems with minimal modifications compared to a DIY setup, and their setups are made to run low and have the right geometry for a lowered vehicle. Yes they are not cheap, but you get what you pay for.
I hope that helps. I know you are going to have more questions so at least this will give you some starting point of reference.
